- Help me with a kill switch please!!!
- Snorkel help
- Headlight chime ?
- trying to find this part #
- Brake bleeding, help?
- Spark plug gap
- What else do I need?
- 22RE ticking problem
- Leaky Fuel Injector?
- Transmission stuck in fourth gear
- ebrake and battery light on
- Hmmm.. Will 2WD Corner Lights Fit A 4WD ??
- 2nd gen 4runner dash speakers
- Big Dilemma? Need Options?
- IS my ECM cooked? 95 tacoma
- special service tool for vacuum booster rod
- head gasket problem
- need help
- Bilstein (or other) shocks w/ BJ etc lift
- 93 toyota pickup engine light intermittently coming on.
- Experience with Rocky Road Outfitters?
- building a 3.0
- Noob question......loosening petcock
- Stumped on start problem
- Addicted Off-Road Bumper...MOUNTED!!!
- Trouble getting leaf spring bushing out. Need to find replacement
- Third members
- crashed my 93 2-door 4Runner!
- help with a 1989 2wd pick up
- Horrible noise, relays clicking, What can it be?
- kc lights.... anyone got pics?
- 4" bracket plus bj spacers= 35's?
- Stiff Manul Hubs
- Can't get truck to run
- 1uzfe flywheel
- 86 sr5 22re
- 1991 V6 3vze Auto Transmission Question ????????
- replacing shocks, buy some for now or wait?
- 86 4runner injector circuits
- Transmission removal tips
- Balljoint Kit
- 3vze switch to synthetic
- Pick me a front bumper!
- Tire Fitment Question
- ifs help
- rear door light on the dash is on
- Losing patience with v6 valve adjustment
- Cleaned up the pickup
- Our Yotas (past and present)
- 1990 and 1993 Radioillumination and speaker questions
- 4.56 gears lockright locker an 31.1250/15's
- lc coils...... ROCK!!!!!!!!!
- orange lift kit?
- Blown head gasket, advice?
- *New tires!!!! 33x10.50 BFG All Terrains, pics inside*
- can i use any 2nd gen doors for all 4 of my doors
- finally passed smog...but got problems
- Inflatable Rear shocks '94 4Runner
- Length of a W58 input shaft?
- removing hitch and spare wheel from my 87
- BAD compression... is it over?
- Look what Jay scored!
- brake rotor upgrades...how hard is it?
- a little BC IFS wheeling pics and vids
- The coils have arrived!!
- Fuel pump constantly running
- Missing Wire
- '88 pickup running light diagram
- inner door panel removal
- looking for a SKID PLATE
- Changing my torsion bar bolts
- Removing LCA with a twist.
- Yay! another rear window problem.
- dirty 30's wont fit, any evewr ground out their knuckle ball?
- flat bed
- Where is timing plug to short out?
- All crank and no start
- ?? 3" rear and bj spacers in front??
- Bad Diveline Vibrations
- weird ticking noise
- Torsion Bar
- 4runner coils i want new ones
- Camper or no camper?
- Speedo cable gear?
- exhaust torx studs
- Free 4Runner!
- Engine noise in radio
- acetone in fuel for better mileage???
- Body Lift shifter problem? Here is the fix.
- Any guides to removing the pistons?
- lce header studs?
- Idle around 500 RPM even after adjusting up
- Anyone running with a Utility Rack?
- Has anybody ever put a inner cage in a 4runner
- My rear diff is leaking
- herculined my floorboard. pics
- Chirp/Squeak Possibly Related to Clutch?
- 3vze oil galley plugs
- Homebrew bumpers
- Brake Problems
- Bed Rust - Is this fixable?
- Finally went wheelin
- New Paint....what next
- anyone have an ECU go bad?
- Everybody read this need help with power windows
- What do the Head Rh and Head LH fuses do underneath the hood
- 22re rebuild parts gathering
- Rear wiper ??"s
- Rear adjuster Kits???
- relays for electrical windows
- 95 4Runner Alarm Questions
- 95 4runner key fob
- Connection off the EFI Chamber
- Head gasket how to
- '95 diesel 4runner transfer box noise (VIDEO)
- Can you remove a transfer case without removing the tranny?
- front shakes/wobbles
- Idle high 200 rpms (it may be my fault)
- Hardtop Bolt Size?
- 22r connecting rod bearings
- Shifter popped out
- I can't get the front IFS diff cover to come off....HELP
- gears
- New to the fourm :) oddly enough, I have a question.
- Grant 414 challenger steering wheel
- INFO about Moog pitman and idler arms
- Need Diagram on how to remove dash
- Silla radiator anyone?
- Help!! part number for 3vz-E camshaft oil seal
- What's missing from my clutch release cylinder?
- shifting becoming difficult
- Half doors, pictures.
- "High Clearance" exhaust Idea questions *pics*
- Its still there......the ticking that i thought was rod bearings
- BJ's and Coils. HA!!!!
- Does this need to be capped ?????
- 87 ECU needed
- brake and charge light on
- brake booster or master?
- PLEASE HELP!! Fuel pressure
- Help taking apart the dash
- horn beeps only when turning....worn contacts
- red hot cat, wont start !!88 3vze
- Suspension really bouncy and really squiky
- yoke?
- Help: IFS diff - swapping longside ADD axle w/non-ADD axle
- knuckle rebuild question
- What i can do to fill in the area between the fenders and interior panels? Too noisy
- Ooops... Slung a rod. What motor should i go with.
- Need Help. Low idle after running the air
- Baja Mule rooftop storage
- body lift issues
- timing chain guide + slack. how long do I have, doctor?
- noise from under truck
- cant get dash back together
- suspension noob question
- Camber issues
- A Couple of IFS gear + locker ?'s
- painting new wheels
- Pain job question
- what is this hose called? 91 22RE
- Broke 250k today.
- coil overs on a 93??
- Grinding Noise
- mystery coolant leak from under intake
- 5vz-fe to w56
- Aluminum lug nuts?
- parts compatability 88 to 86 22re
- Weird electrical glitch
- AC Questions mine doesnt work need new one.
- Reverse switch?
- New guy, has stalling problems 88 22re
- For those that have done their 3vze timing belt...
- Parting out 1990 pickup. 22re 5spd
- rear U bolt flip kit and shock mounts
- check out my polished turd!!!
- Lower Control Arms
- 86 22re starting/ idle issues
- 1986 4x4 sr5 efi 22RE
- 1988 V6 Ex Cab 4x4 auto rear drive shaft..What other models fit it?!
- 22RE Backfiring
- Torsion bar oem replacement colors
- 4crawler hi-lift mount and a bikini top mounting questions
- 92 extended cab - totaled - Insurance payout?
- Distributor bolt SNAPPED- not a timing question
- 20+ degrees BTDC
- Clutch slipping
- Finally Regeared
- Head Gasket Filure
- attention to engnbldr cam 22re owners - timing. i need your help.
- Ordered a TG crossmember and....
- 1987 4runner starter is going out....
- New here...have question about idle/tranny fluid
- Installing a new bed
- No electrical power?
- Clunk at start up after trans swap
- How to find a fuel leak?
- Tail lights lit...Keys out, etc.
- Transmission Confusion
- My 88 4Runner and My Dad's 07 Tundra
- 80 amp fuse help
- what emissions crap can i take off my 93 22re and how do i do it?
- Help I need sound advice about 4runner looking at buying
- should I trade my 4runner for this truck?
- head gasket
- marlin rock crawler shifter seats FTW!
- Water pump and timing belt change-Anything else while I'm in there?
- Blown 94 v6 4runner, stick to 3.0 or swap to 3.4?
- 93 toyota truck grinds in 3rd and 4th gear ?help!
- New lift, tires and wheels... Gearing?
- Ball Joint Spacer measurements?
- Plug Kit?
- Yet another 3vze idle troubleshoot
- 32 spline aisin hub?
- 88 Pickup 2wd 22r Head Gasket Tips
- how much is a 87 rear window motor worth?
- I have a 90 4-Runner with starting issues!
- sunk the yota
- Header questions
- Idler Pulley for 22r/e
- Bushwacker Cut-outs?
- questions about Relays and checking them
- 1988 4Runner original catalytic converter
- My Transmission is making a godawful noise!! *Video*
- aftermarket AC installation
- sliding back glass
- 5.29 and 265/75/16
- question about 63 chevy's
- t-100 lighting problem
- Surface finsh for head gaskets
- how to remove side windows?
- 1986 4 runner for sale
- 3.0 Rebuild
- 4:88 gears and 31" Tires?
- 914runner 3.0 fuel leak
- Things required for a small lift.
- help!!! 95 sr5 pickup
- Adding an outlet to the back of my 87 4Runner - Need Help
- What do these wires go to??? PLEASE HELP!
- 2 Fuel filters? Accel issue. Help
- need help on my HID
- New rebuild, clutch won't engage gears
- *12 volt guy e-locker harness/switch*
- A/C for a 93 Toyota Pickup HELP???
- Backspacing
- Mysterious Engine Stall
- Front locker = extra traction, extra repairs, or both?
- A little rust on this t-case...go or no go?
- just finished headgasket couple questions
- Fuel pressure reg hosing?? Operation?
