Where is timing plug to short out?
Old May 19, 2009 | 08:16 AM
calltrex's Avatar
searched everywhere online to find where it is. found couple pics but dont really show where in the harness the plug is.
my 22RE engine and harness is out of a 88 4runner
If anyone has a picture of theres that would be awsome.
where it is, what it looks like
Old May 19, 2009 | 09:07 AM
Junkers88's Avatar
Right behind (towards the back of the truck) the main fuse panel under the hood on the passengers side inner fender. It's a little black box. Pull the top off and jumper the T1 and E (I think) terminals.
Old May 19, 2009 | 09:30 AM
calltrex's Avatar
Thats the problem. this engine is put in a rock crawler so there is no locations.
if i could see where aprox the plug comes out of the wire harness i can probably find it on mine.
i dont want to short the wrong plug or something..
Old May 19, 2009 | 09:47 AM
Junkers88's Avatar
I'll have to wait until I get home to take a look and possibly snap a photo. Sorry about the mix up.
Old May 19, 2009 | 10:03 AM
TOYOTA 1's Avatar
yea on my 91 its where junkers says it is, but on my 86 runner its on the drivers side plugged in to the fender.
http://www.4crawler.com/4x4/CheapTri...CheckConnector
Old May 19, 2009 | 10:35 AM
abecedarian's Avatar
If it's not the stock cab... hard to say if things were moved / rewired.
Here's the connector on my 88:
Old May 19, 2009 | 11:24 AM
calltrex's Avatar
i found 1 plug hanging by itself. 2 wires.. sorta near the coil
Old May 19, 2009 | 11:28 AM
That looks like the culprit...
Can you tell what colors are the wires?
Old May 19, 2009 | 11:30 AM
calltrex's Avatar
kinda looks similar to the one circled in blue
are those just rubber holders? what do those plugs look like when they are pulled out?
Old May 19, 2009 | 11:37 AM
calltrex's Avatar
looks like yellow and black wires
Old May 19, 2009 | 12:09 PM
wait.. you said 88 harness? if that is the check connector, that wouldn't be an 88 harness.
Old May 19, 2009 | 12:33 PM
calltrex's Avatar
i know its a 88 engine. im sure the guy would have took the wire harness out of the same vehicle.
unless its a split year and the harness changed?
Old May 19, 2009 | 12:41 PM
4Crawler's Avatar
Yes, those are just the factory retainers for the plugs:
Pretty simple connectors, the O2 sensor test connector is round with 1 terminal. The timing connector is round with 2 terminals (that you connect together with the jumper) and the other round plug has 3 terminals. Hard to mix them up.
Old May 19, 2009 | 02:38 PM
calltrex's Avatar
whats the round plug with 3 wires used for?
guess ill go try jumping this 2 wire round plug. see what happens
Old May 19, 2009 | 03:20 PM
4Crawler's Avatar
As noted on the web page above, that connector has some of the ECU O2 circuit test voltages, like the Vf signal. I think there is some mention of it in the FSM.
Old May 19, 2009 | 05:09 PM
calltrex's Avatar
Thanks for the info guys...
I jumped it
didnt do anything
timing still the same at 5 degrees
not much else i can do.
cheers
Old May 19, 2009 | 05:14 PM
4Crawler's Avatar
Not sure what you are trying to do, but the base timing not changing after installing the jumper is often due to a bad TPS adjustment:
- http://www.4crawler.com/4x4/CheapTri...roubleshooting
Old May 19, 2009 | 05:20 PM
calltrex's Avatar
thats asuming that was even the right jumper connector in the first place..
was just trying to set the timing properly. i just rebuilt the whole motor.
motor runs fine so far
Jun 1, 2021 01:51 PM
toyota32
Jul 6, 2015 05:42 PM
Jnkml
Jul 6, 2015 01:20 PM
Vargntucson
Jul 4, 2015 12:15 PM
