I can't get the front IFS diff cover to come off....HELP
Old 05-16-2009, 04:55 PM
89silverpu's Avatar
I'm trying to take the IFS diff cover off of an ADD v6 4.88 diff to switch axle tubes with my 4 cyl non ADD. Seems like the gasket is acting like a glue, how should I go about getting it off. I've pounded it with a rubber dead blow mallet no go, tried wedging a flat head inbetween the cover and diff and still no go. Any ideas?
Old 05-16-2009, 04:57 PM
yoterr's Avatar
maybe try a razor blade to cut into it and wedge that in there, then get the screwdriver and wedge that guy in there
Old 05-16-2009, 04:59 PM
89silverpu's Avatar
Oh good idea I didn't think of that I'll go try it!
Old 05-16-2009, 05:06 PM
randito's Avatar
brass drift?
Old 05-16-2009, 05:07 PM
89silverpu's Avatar
no go...
Old 05-16-2009, 05:08 PM
89silverpu's Avatar
Originally Posted by randito
brass drift?
Believe me it aint comin off by pounding it with anything except maybe a sledge hammer but that would mess it up
89silverpu's Avatar
Anyone else have this problem before?
Old 05-16-2009, 05:20 PM
grant526's Avatar
did you pull the side shafts already? They have to be removed before the 3rd member will drop out? From my best understanding they have to be out. . .
Old 05-16-2009, 05:28 PM
89silverpu's Avatar
The diff cover is what's not coming off. This is an IFS unit not like the 8 inch thirds like you have. There is an actual cover like on a dana axle on it that won't budge.
I have to take the cover off in order to remove the axle tubes and half shaft. there is a clip that must be pried apart...
Old 05-16-2009, 05:29 PM
iamsuperbleeder's Avatar
the 3rd member with the gears, yes, the shafts would have to be removed
but I believe the front diff on IFS, the front cover portion is removable, like your average GM, Dodge, or Ford diff. only thing special about it is that it's got a mount on it that connects it to the frame via a rubber bushing
I've cut through cured gasket material like that with guitar string wrap each end around a peice of wood, and run the wire in between the front cover and axel housing, and run it back and forth to use it kinda like a saw. even if you can only get it so go a little bit, you should then be able to get a flat-head screw-driver in there a little, then tap on it with a hammer to wedge it in and cause the two to separate
you DID get all the bolts out, right?
Old 05-16-2009, 06:04 PM
89silverpu's Avatar
haha yeah I got all the bolts out
I ended up grindin my big pry bar down on the edge (thank you craftsman tools I'll just go get a new one now) and slid it threw the bushing and leveraged it off kinda so I got it off!! It was on there tight!
Thanks for the ideas though guys!
Old 05-16-2009, 06:17 PM
cadman's Avatar
I had the front diff cover off last weekend, and it took a few minutes of tapping at the mounting boss with a plastic dead blow mallet, but it eventually came off. The only thing holding the cover on (besides the screws) is whatever sealing compound was used; RTV, FIPG, etc..., and superbleeder is correct, you do not have to remove the gear shafts.
A good size dead blow mallet will knock it off without damage, a rubber mallet will just tickle the cover.
Old 05-16-2009, 06:23 PM
89silverpu's Avatar
I did use a dead blow mallet and it didn't come off. I worded it wrong earlier.
Old 05-16-2009, 08:01 PM
dark_fairytales's Avatar
To anyone else who may have this problem in the future. Soak the bolt holes with acetone for 30 min. than pound away, pops right off
Old 05-17-2009, 09:24 AM
grant526's Avatar
Sorry everyone. I wasn't trying to upset anyone. I haven't worked on my buddie's 93 much, but i have removed the entire diff carrier once. I didn't pay a lot of attention to it, but I didn't remember seeing a removable cover on the front. Sorry! The way y'all described it does make sense.
Glad to hear your got the cover off!!
Good Luck with the project,
Grant
Old 05-17-2009, 02:12 PM
89silverpu's Avatar
Grant
No worries I don't think anyone was butt hurt by it If it was a solid front axle you'd a been right
Old 05-17-2009, 02:49 PM
highonpottery's Avatar
i just got mine taken apart a few days ago and that sucker was on there. ended up using a thin, rigid putty knife and a hammer and then it just pops right off - took one whack. I've still gotta check the thread i posted asking questions about swapping tubes, but how are you dealing with the oil seal?
Old 05-17-2009, 06:40 PM
89silverpu's Avatar
I don't know just yet, I just realized I had to do something about an oil seal after you said something...and I just researched it a little bit.
Anyone know the part number or where I can get an oil seal for the swap? Or a link to some more indepth info on it?
Thanks for the heads up highonpottery
Old 05-18-2009, 06:28 PM
Stuwy123's Avatar
Here's what I use for reference:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
It's handy to have around when you can't find that last bolts holding something on.
Old 05-18-2009, 06:47 PM
89silverpu's Avatar
Nice! Thanks for the link!
Quick Reply: I can't get the front IFS diff cover to come off....HELP
