PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. 1993 22re high oil pressure?
  2. Where to buy a tailgate window motor in Canada?
  3. 22RE keeps having overheating issues
  4. 1987 Oil leak
  5. Hey guys! Back with a new(er) truck!
  6. 92pickup seat swap with a 90's Tacoma???
  7. Washer Fluid Reservoir
  8. Code 14, Help por favor
  9. 1987 sr5 Xtra cab
  10. 4Runner AC problems
  11. Only starts and runs without oil... 😳
  12. This again...
  13. Thoughts?
  14. Whats Up Everyone!
  15. 90 pick up will not open from outside.
  16. 95 Pickup 3VzE strong exhaust smell, hesitating when cold
  17. 20rblock 22rehead together?
  18. New Member - 1991 22RE Pickup
  19. 1987 pickup stereo screw size
  20. Missing vacuum cap
  21. '92 T4R will turnover but struggle to start
  22. Fuel pulsation after EGR/PAIR delete, 94 3VZE
  23. 3vze runs and dies
  24. Aisin hub bearing?
  25. Stripped flywheel bolt hole
  26. Sourcing a 3.4?
  27. Dip Stripping? New Jersey
  28. Question about 3VZE camshaft & removal
  29. Front Griile 1986 > 1993
  30. Which 3VZE Head Gasket Style/Brand??
  31. 1988 Toyota pickup 22RE stick shift bogging out & won’t shut off unless in 1st
  32. Surface good enough for mls 3vze?
  33. Rear main seal advice
  34. Rear Diff sprung a leak, do i have to take it apart?
  35. Idler Arm to Centerlink Boot Issue
  36. 1990 22r with 4speed transmission value
  37. Pitman arm/ idler arm /steering
  38. Finally fixed my tailgate window
  39. Duals Setup HELP!
  40. 88 3VZE 5speed- real main seal cover removal-HELP
  41. Introduction, new 86 pickup, couple questions
  42. Power steering pump
  43. Fluttering sound under load?
  44. 22re-t engine not starting
  45. ford taurus swap help
  46. '93 4Runner V6 Not Starting
  47. Rack and Pinion Steering Upgrade
  48. 1990 Toyota 3.0 V6 no cold air from ac
  49. Back window problems yet again. Back Door dash light always on
  50. No speedo and no Volt gauge
  51. My 4runner got rear ended!
  52. '90 database
  53. 1988 Carb Conversion for a DD
  54. clutch switch replacement
  55. 87 octane vs 91 octane 22re issues
  56. 1992 4runner SR5 Rebuild!
  57. Need help piecing my front bumper & grill to my 1986 pickup
  58. Sc-14 supercharger on 3.0
  59. Broken rocker arm tower
  60. I'm new and dumb
  61. 3vze head gasket problems
  62. What's this cable called? w/ Picture
  63. 1994 Pickup
  64. Wiring harness routing 87 re, lost all power after motor swap
  65. EGR Valve nut missing...
  66. Rear wiper variation
  67. 94 toyota pickup rear speaker not working.
  68. 1990 22RE EFI temp sender (green) plug
  69. Back up light grommets for 2nd gen. w/tailgate spare
  70. Stalling on take off?
  71. T4R first gen - 33"x10.5r15 in spare location
  72. T4R first gen - Spare tire hoist/winch for alloy rims - chain or cable?
  73. 3VZ-E A/T to 22RE MT Swap Cabin Wiring Help.
  74. Possible bad fuel gauge?
  75. 1987 Turbo misfire help
  76. 91 4runner v6 no spark
  77. 87 4x4 auto transmission problems
  78. 87 4x4 auto transmission problems
  79. 3VZE Rebuilt and having trouble dialing it in.
  80. Diagnosing brake booster
  81. lug nut help?
  82. glovebox lamp
  83. 1994 p/u third brake light
  84. Wire Identification - Help!
  85. Air intake hose clamp 22 re
  86. What the heck is this hidden hanging thing?
  87. Build Brainstorm
  88. Disable daytime running lights?
  89. Aftermarket fuel tank
  90. 22r cuts out when accelerating
  91. Parts manual?
  92. Bumper question
  93. Refurbished shift knobs
  94. How blown out is my power steering system?
  95. cv axle flange nut P/N
  96. 88 heater control assembly lever retainer clips? Sources?
  97. 4wd drive locking hubs conversion.
  98. instrument cluster
  99. Hot start issues. Please help me if you can.
  100. Looking for interior lights wiring diagram
  101. Fuel Line Hose From Pump Bracket to Main Fuel Line
  102. 1986 Toyota lock cylinder
  103. New to me 4Runner - Failed California smog
  104. Engine Tune-up
  105. Newly acquired '91 3.0, lots of questions.
  106. Hilux sfa 1996 2,8 d
  107. San Antonio
  108. Code 24 IAT circuit issue
  109. Losing power after shifting into second gear
  110. Wiring harness question
  111. All you wheelers need to check out what this guy is doing
  112. Head Gasket Issues w '89 3VZE Pickup - On its last legs?
  113. 3vze Accessory Brackets (Power Steering, Alternator)
  114. Acceleration issues
  115. 86 Pickup with 82 22R rebuilt and not turning over
  116. Help Identifying part name
  117. Difficulty of installing ac from 95 v6 4wd 4runner into 93 22re 4wd pickup?
  118. W56 shifter gasket washers?
  119. 91 4R Fuel filter nuts rounded over
  120. 1986 Toyota pickup 4x4 shift pattern & procedure
  121. P/N's for starter
  122. Part ID help!
  123. Part ID help!
  124. center console
  125. Orientation of clutch disc for 3VZ?
  126. 1st Gen 4runner New Tailgate Panel
  127. 1993 Toyota t100. The speedometer mileage gauge stopped working
  128. Swapped 95 cable driven sr5 cluster into my electronic speedo truck...
  129. Something is bent?
  130. 1987 2wd short bed 22r engine swap options
  131. 89 Toyota 3.0v6 no power to my distributor after rebuild.
  132. Show us your subwoofer enclosures
  133. T4R first gen - Remove the ignition key cylinder
  134. 95 4Runner 22RE Hot start problem
  135. 95 4Runner 22RE Hot start problem
  136. Fuel pump sanity check
  137. SR5 Tach reading erratically
  138. What is this port??
  139. 1990 22re bench seat cupholder
  140. 2nd gen 1990 4runner tailgate stuck
  141. 91 toyota pickup for sale
  142. 89 Toyota Pickup Power Steering Issues Now Won't Start
  143. What is the difference between these??
  144. Recent Rebuild Poor MPG
  145. in cab full size spare solution
  146. New AC Soft lines
  147. 86 2.4D Cranks Slow
  148. What is the best rust converter/sealer?
  149. 3VZE Toyota Overhaul Kit # 04112
  150. Load Proportion/ABS or both?
  151. Anybody else have these?
  152. Trying to use connector from 4runner on pickup
  153. Stamped tailgate
  154. Lubricating Throttle Speed Cable- 3vze
  155. 1990 Toyota ( front brake issues )
  156. 1992 Toyota pickup
  157. 19
  158. Truck bed
  159. Should head gasket holes be open? 94 3.0 L
  160. RPM off the chart?
  161. LCE Pro Torquer Camshaft in stock head questions
  162. Windshield trim
  163. 1993 pk
  164. New reman'd alternator instantly overcharging! DOA/coincidence or wiring short?
  165. Coolant issues!
  166. MT shifter seat
  167. Battery isn't getting charged but alternator is making power?
  168. Do I have burnt out cluster lights?
  169. Engine Rebuild Break-in Period
  170. 1989 1/2 4runner
  171. 89'-95' Toyota Pickup Build Questions
  172. Clark Co EGR delete? How much emissions will it raise?
  173. 1990 pickup fuel injectors
  174. Does anybody have these installed?
  175. Some may say its overkill...thoughts?
  176. 1987 front turn signals
  177. Please help! Intermittent no start.
  178. Somebody must be able to get this measurement
  179. My first!! Toyota 4x4
  180. Rebuilt 22RE's: How many miles can they rack up? Which brand do you recommend?
  181. 94 Toyota 4x4 interior parts
  182. Another 22re fuel pressure thread
  183. Lack of power chased for 2 mths
  184. fuel delivery when starting
  185. shop manual
  186. Input/Pitman shaft bearings for steering gearbox. overhaul
  187. Headgaskets | Engine Swap | Manual Conversion
  188. Where in the world do i source new cab mount bushings
  189. Oil pumps differrent and fuel injector wiring?
  190. Leaf spring pads spacers and camber adjustment
  191. '89 intermittent no crank
  192. Centerlink/Steering damper fitment
  193. 88 3VZE FUEL SENDING UNIT- -Help
  194. Build gone wrong
  195. 88 Toyota v6 5 speed 4x4 engine harness interchangeable?
  196. Is Fel-Pro Headgasket a bad choice?
  197. 1990 V6 5 Speed considering buying for $2000
  198. 22re will run good for 30 seconds then die
  199. Co relay
  200. T4R first gen - Climate control cable short?
  201. Replaced Combination Wiper Switch now it’s not working.
  202. Can't remove Manual locking hub and cv axle.
  203. Coolant not overflowing into reservoir?
  204. Power steering box rebuild help!
  205. How to prevent 3.0 issues?
  206. 86 4Runner 22re problems after TPS replacement
  207. 88 Yota Won’t start
  208. 94' 22RE metallic rattling came out of nowhere
  209. 22re keeps dieing
  210. New help with fan clutch
  211. What's your experience with what brand? Chassis & Body Primers/Paints......
  212. reburbish door panels
  213. What wheels and tires with rear disc brake conversion
  214. 1992 Toyota pickup won’t start after reconnecting battery
  215. shifting woes
  216. Need '89 22RE cooling sys help!
  217. How to determin if RICH or LEAN OBD1 & Scope
  218. 1994 Toyota Pickup Speedometer not working.
  219. 22re alternator plug
  220. Any tips? 3VZE bypass coolant leak
  221. What is this Bolt - 3vze
  222. 22re swap no crank
  223. Replacement AC Evaporator Switch and Line?
  224. Reset ECU and now it wont start!
  225. Intermittent Clicking
  226. Need help figuring out wheel fitment
  227. One more false start and,,,
  228. ECM Wiring
  229. Ignition Problem with 89 Toyota Pickup 3VZE
  230. suspension
  231. W56B Center plate bearing play... looking for advice?
  232. 3VZE - How Many miles on your HG
  233. Help!! 22re pickup Engine coolest temp wiring
  234. 94 22re 4x4 pickup vacuum lines
  235. Diff leak help
  236. Burnt my 1989
  237. 89 22re wiring schematics
  238. Stuck in gear
  239. 94 22re bracket
  240. Trying to source a spring for Aisin hubs
  241. 94 heater only warm / belt squeaky ??
  242. Crazy Jerk from Drive tires engaging/not engaging?
  243. After new mass airflow sensor it won’t start
  244. 1995 4Runner #VZ-E Cannot set ignition timing
  245. Need help identifying this piece!!
  246. Shock/Spring from 2nd Gen
  247. 88 fender question
  248. 3vze coolant leak just under the pleneum?
  249. Could someone please tell my incompetent ass what this little gold cylinder beside...
  250. Steering column shroud
