ECM Wiring
Old Feb 17, 2020 | 07:18 AM
Old toyota's Avatar
Smile ECM Wiring
Need help or advise on a swap. Installed a 3.0 with a manual transmission from a 91 4Runner. Had the doner and everything right there. The body harness was ruined. I found another harness from a 92 4Runner . The H1 and H2 plugs match the engine harness. Everything is connected. I contacted the seller and he claims the body harnness came out of an automatic 4Runner. The ECM is from the manual. I have read several post of not having to do any thing to repinning the entire Connectors that connect to the ECM. Is all that necessary? Can the neutral switch be jumpered out to make it think it is always in neutral so it will start? If so there arseveral plugs that could possible reach to the middle console area that may have connected to the transmission. If it is not an automatic body harness did the “Clutch Start” button have more than 3 wire connecting to it?
I would appreciat any help or direction on any build. Or whatever.. I am sure someone has done this but sssssssooooo much information
i apologize In Advance of asking about something that has probably been done a million time.
THANKS.
Old Feb 17, 2020 | 08:16 AM
superex87's Avatar
Your best bet is to find the wiring diagrams for both harnesses and compare them. The auto harness is a little different but I dont know the specifics.
Drednaught
May 3, 2017 04:36 PM
ianjadkins
Dec 14, 2016 04:35 PM
90yota88
Oct 2, 2014 12:27 PM
amites
3.4 Swaps
Jul 30, 2014 02:57 PM
robwise
3.4 Swaps
11
Oct 16, 2012 06:14 PM
