3.4 swap harness question
Old Oct 10, 2012 | 09:33 PM
robwise's Avatar
I have a 96 5vz, a 97 mt ecm, and a 01 auto harness.
Anyone know if I will be able to repin the harness I have? Or will I need an older one?
Thanks
Old Oct 11, 2012 | 05:32 AM
vasinvictor's Avatar
You can probably repin it. Seriously though, you will have to get EDWs and compare connectors, colors of wires, and locations. There's absolutely no other way to go about it. You might also have to get another connector or two and repin those if you 01 harness doesn't plug into the 97 ECM.
Old Oct 15, 2012 | 02:33 PM
robwise's Avatar
Ok so I guess I have to order the ewd's from Toyota? Anyone know if they are any different from the wiring diagrams in my Haynes manual???
Old Oct 15, 2012 | 03:15 PM
If you're good with EWDs and don't mind wading through the occasional mislabeled or colored wire Haynes would be sufficient.
The general consensus here is Toyota manual from TIS is the way to go.
Old Oct 15, 2012 | 05:34 PM
robwise's Avatar
Ok cool, yeah I have never done anything with ewd's, will I need the 01 & the 97, or just the 01? I already know I will need the 89
Old Oct 16, 2012 | 05:11 AM
waskillywabbit's Avatar
You need the wiring diagrams from any component you use that has or uses wires.
If all different years then you best compare diagrams.
This is why you get a donor vehicle instead of Frankensteining, much less of a pita.
:wabbit2:
Old Oct 16, 2012 | 05:23 AM
robwise's Avatar
That's what I thought, just trying to confirm before I had more manuals then I needed. I would have loved a donor, but it just wasn't an option for me. I'm not in a hurry to finish my swap though, and a little extra work never killed anyone haha.
Old Oct 16, 2012 | 05:24 AM
Truly spoken like someone who has never done this. You'll learn the hard way.
:wabbit2:
Old Oct 16, 2012 | 11:32 AM
robwise's Avatar
Your right I've never done this swap before, and I don't have space in my garage for a donor. This will probably by too hard and I should just give up now
Great attitude
Old Oct 16, 2012 | 11:34 AM
You really should.
A 96 motor to a 97 ecu with an 01 harness will be a wiring nightmare for someone already clueless.
:wabbit2:
Old Oct 16, 2012 | 03:53 PM
robwise's Avatar
Haha, I disagree, I don't believe in "I can't" or "give up". Geuss we were just brought up different. I had a few questions, so i asked them. No one was born all knowing. If you don't have anything productive to contribute, don't bother me. I don't appreciate you negative attitude.
Old Oct 16, 2012 | 06:14 PM
If you can't handle the facts of the answer, don't ask the question on a public forum.
It's not negativity, it's simply experiential wisdom telling you that you've chosen poorly.
:wabbit2:
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
88yodabasket
Jul 13, 2015 01:32 PM
94whiterunner
Jul 12, 2015 07:15 PM
Coreyr384
Jul 10, 2015 11:13 AM
Cplmike
Jul 8, 2015 08:47 PM
