- 22re problems after washing
- Which Clutch
- Truck Died: Overfueling?
- cold starting issues 22re
- Newbie with a(nother) 3.0 start/run problem
- 1990 4runner might have broken timing belt?
- very high idle
- Starting issue?
- Front axle snap ring question.
- timing question
- Is it possible to twin turbo?
- 22RE Exhaust manifold leak fix
- Repairing/cleaning up heater resistors?
- Am I missing a body grommet?
- Crank pulley removal
- transmission swap?
- 92 4runner lost power
- pinion from hell....
- Once again no power in 3.0L V6
- MSD Ignition Controller Help
- 1988 4runner maf
- Automatic/Manual Transmission swap
- Gas Leak
- Clicking Behind Glovebox/ Fuel Pump Failure
- 3vze radiator pressure test ?'s
- 2 injectors getting no power to them????
- What did i get into??
- SCARY start-up rod/valve knock/clatter!
- My New Old '87 4runner (4x4, 5 spd, 22re)
- '91 Toyota Pickup Clutch Pedal Help
- Rear Window Help...
- Still can't shift - new parts/fluid/gear
- Turbo vs 22re....Lets Discuss And Share Some Pics...
- Bumper Buildin Options?
- Clutch parts or Tranny going bad?
- Pedal Assembly swap
- Lets talk about cold start timer switch
- Knock Sensor for 88 3.0 Pickup
- Tonneau cover install with crossover toolbox
- heat selector switch/lever doesn't do anything?
- Torque spec for Seat belt Bolt?
- fuel leak. Need help. fire issue?
- 1990 3.0 loud squeal
- Will my 86 transmission mount to an 84 22r
- Looking to rejoin 4runner society...
- Anyone know when the Circuit Opening Relay design changed?
- 22R EGR passage on exhaust side of head...where's it go?
- 4cyl 6cyl rear drums
- Irratic Start Problem
- rims/wheels
- Vibrations on highway decel
- New Ox sensor yesterday Ox code today
- 1992 3.0 V6 EFI oil leak
- Need some brake advise on 87 4runner SAS
- transmission mount fell out
- Toyota U-Haul Box truck
- brakes are bad please help
- Revised 3VZ-E Connecting Rod Bolt Tightening Procedure
- 88 pick-up V6 (Running list of To-Do's and Ideas)
- ID my header?
- Bench to buckets swap...
- The parts list for installing an OEM oil cooler on a 3VZ-E w/o one
- Code 63 help
- Boxed Frame Inside Rust Removal
- headlight conversion
- Fuel Prob?
- How Rare are they? 2nd Gen. 2Dr 4Runners
- Clutch Master Cylinder???
- Over heating issues
- 22RE A/F Ratio Tuning
- 22RE running rough and black smoke
- weird hesitation/power surge while driving
- Winding noise in transmission.
- 4runner bonnet onto Hilux - same year
- Battery Terminal Check & Fuse Box Cable
- Advice on engine oil... should I change?
- Spark plug shot out, loud knocking, some smoke
- Reverse Lights
- '87 SR5 Wire Harness - Does it Have the Cruise Control Pigtails?
- Not your average starter problem! Help!
- Wiring harness from 94 runner to 90 motor... HELP!
- Strykersd's Turbo 4runner build
- Bumpers interchangeable from 91-95?
- 2nd Gen truck doors on 1st gen runner?
- 3.slow Rad Fan on a 22re??
- strange engine noise
- Momentary Low Idle
- 22re smog problem... HELP
- 22re IFS Oil Pan Removal
- wheel bearing re-pack advise
- Has anyone done a snorkel on a 94 22RE
- ID this sensor on 22RTE 87 4Runner
- Exhaust downpipe removal!!
- Proportioning valve
- need help with my newly aquired 4 runner
- Fixing water temp sensor. Help identify cables?
- cylinder 3 and 4 trouble- 22re
- Sick turbo
- Removing reed and egr valve/ systems
- Year and model confusion :(
- 4Runner front brake job
- 22RE Rough Idle Stalling at Stop Light
- 90 4wd front bumper on 94 2wd?
- V6 3.0 2000 rpm help!!!
- Aisin Clutch - Flat Side Flywheel
- 3.0 v6 wont idle down
- 89 4runner, non running engine
- Extra power
- V6 3vze - Code 25 and causes. (And another thing)
- Pickup manufacturing locations
- 22REPerformance 3mm oversize TB
- 3vze drive belts - part numbers and where to buy?
- Brodave
- 4runner tailgate removal?
- Trouble codes and interesting senario
- 3vze valve cover
- 3.0 dual exhuast opinions??
- v6 missing when cold
- IFS lift decision help
- 91 Clutch issues
- Ignition hot fuse?
- No crank no start
- 86 22re\no cold idle up related to stumble?
- 87 22R Valve noise, need help
- 11 mpg on 92 4runner...
- intake coating?
- Timing
- What A/C air temp?
- 1993 Toyota 22RE won't start (Fuel pump?)
- 22RE Total Timing Help
- 3vze wont start HELP!!
- Attempted to fix exhaust leak, found this. What is it??
- cruise control issue on 91 4Runner
- Dipstick Issue
- Grill and headlights on my 94
- Evap canister question
- Passenger Rear upper link, install help needed.
- Do you need gasket adhesive under the valve cover grommets?
- SS fender trim
- runner cargo area carpet
- Best key blank
- Heater Blower Removal? 91 4Runner
- 91 2wd engine into a 86 4runner possible?
- EGR Delete kit
- ruuner ruff after head swap on a 22re 4 runner
- 3vze low surging idle.
- 1994 3VZE idles super high
- Where do I mount this thing of wires?
- screaching noise when i let out the clutch?
- New to Toyota, but liking it so far!!!
- Noise when throttle barely pushed!
- Which cam for hybrid engine
- 1982 22r in a 1991 efi 4x4 ?????
- Ongoing 22RE issue, Only the Greatest of mind should enter here!! :)
- can't decide 901 or lc 80 coils
- california catalyic converter?
- IFS brass bushing trouble
- timing chain replacement no start (kinda) help!!
- Clutch spongy, found this leak
- Where can I get door glass seal?
- 93 roof rack options
- new rig
- '92 Pickup v6 Coolant Leak
- Aftermath gremlin
- **help** 91 22re pickup ignition timing
- IFS Third Member Swap Questions
- Removing engine question
- 88 yota takes a long time to start
- What size are the front bumper bolts??
- Lucas Heavy Duty gear oil?
- swapping non ADD tube to ADD diff. Searched and now confused
- Plastic control lever panel on dash,removal??
- no horn power at steering column
- 1989 Toyota Pickup 4x4 - 22re/5pd (No Start)
- Pics of snow wheelin!
- starting idle bad when not warm or not cold...
- Will a 94 3vze swap into a 90 4runner?
- Are 4 cyl carriers interchangeable?
- tightening alternator belt
- 89 Toyota pickup V6 engine problem!!!! HELP
- Dual Battery System
- Header issues
- What would you do with this 22ret
- Loud squealing after 3vze rebuild
- Oil leak question
- Is there a fuse for the windshield fluid pump?
- 22re idles/drives rough when hot
- CV Axle Snap Ring won't fit once knuckle is installed
- 3.0 V6 91 pickup Clutch install help
- head gasket
- My New to me 86 pickup
- timing chain mileage
- Seriously,how do i remove my CV axles?
- should i have play in input shaft on rear end?
- front wheel bearing tightening
- 3vze thew a rod
- replacing rear wheel bearing in 1986 truck
- A/C on 85-89 truck or 4Runner
- Driveshaft flange won't line up with rear diff
- Will a newer model cab fit on a 1986 hilux?
- sensor next to coolant temp sensor on 90 22re,what is it??
- Headlight issues
- long bed question
- TPS issues (won't rev past ~2800)
- 91 3vz Pickup
- Engine off - temp sky rockets
- 95 runner 3.0 needs help
- timing for turbo 22r.
- Just Installed Rebuilt Engine, Very Discouraged
- Fuel Pump Wiring Nightmare...
- 3vz vacuum
- Today's Mess...
- Oil Pressure valve
- engine harness question
- Transmission send/return lines on a 1986 22re Truck?
- 1988 Factory Service Manual
- wont start sometimes HELP PLEASE
- toyota misfire
- '89 interior wiring diagram help
- Pair reed valve fail..
- non DD clutch break in?
- Running hot, help!
- Rear Tires not rotating freely
- Lets talk about exhaust
- Power steering adjustment?
- Interior paint code?
- A/T Temp Oil Light Came On While Driving
- Oil Leak Question
- 170 Amp Alternator Upgrade?
- Looking for 22re pickup mpg video
- 22RE Can't keep tension on alternator belt?
- Looking to delete the EGR out of my 87 single cab
- 94 toyota truck steering wheel
- 93 pickup 3vze speedo wiring?
- a jingle noise from engine
- Will a Plastic Front Bumper Corner off a 1988 2wd Drive fit a 1988 4wd
- Engine pull with trans, transfer case?
- Timing difference between 93 & 91
- 1987 Totoya Truck 4x4 22r wont start
- 91 toyota 4runner 3.0 bad hesitation, feels like its missing help please
- Auto to Manual hub swap
- Yet Another Charge + Brake Lamp Issue
- 22re stutters
- highway speed vibration
- Steering Stop Bolt Caps
- Battery Cable
- Intermitent misfire
