Timing difference between 93 & 91
Old Jan 25, 2012 | 07:03 PM
93tonkatoy's Avatar
I have a 93 pickup 3.0 v6 I've been stumped with. I bought another engine for it. It is out of a 91 model. Is there any differences in the timing setups with the idler pulleys?
Old Jan 25, 2012 | 07:18 PM
justin_4runner's Avatar
one is spring and one is mechanical i do believe.
Old Jan 25, 2012 | 07:22 PM
93tonkatoy's Avatar
I jst figured that out. Thank you tho. Do you know if the belts are different lengths and a diagram on how it is routed. I've been stumped for 3 hrs straight on this thing.
Old Jan 25, 2012 | 07:34 PM
i have put 2 links here one is for the fsm for most toyotas, and the other is directly to the timing belt and how it all goes,
http://www.ncttora.com/fsm/index.html
http://www.ncttora.com/fsm/1990-1995...e/timingbe.pdf
Old Jan 25, 2012 | 07:37 PM
93tonkatoy's Avatar
Thanks. That was the manual I have as well. But the engine going in has the spring.
Old Jan 25, 2012 | 07:51 PM
mine has the spring and the spring goes from the pulley on the passenger side to a hook on the top of the water pump i just had mine all apart but i didn't take any pics i think ill look to make sure,
Old Jan 25, 2012 | 07:53 PM
93tonkatoy's Avatar
Ok. I'll go try it and fill you in thanks again.
Old Jan 25, 2012 | 10:13 PM
93tonkatoy's Avatar
Ok so I don't have anywhere on my water pump to hook it. But I did get it put on and my belt put on and close. Still gotta tinker a bit. Any ideas on tension?
Old Jan 25, 2012 | 10:21 PM
there is a bolt right above the roller or next to it on the side close to the pulley that the spring goes to, that a bracket bolts to and the spring will pull off the pulley to that bracket
Old Jan 25, 2012 | 10:24 PM
93tonkatoy's Avatar
Ok. Well ill check it out after bit. Gotta catch some z's. I would upload pics but I don't know how.
Old Jan 25, 2012 | 10:29 PM
u need to upload them into photobucket.com then use the link from there to the thing that looks like a stamp when u are replying, put the link in there and post it. the pic will show.
Yota.Jay
Jul 23, 2015 08:08 PM
msane99
Jul 11, 2015 08:08 PM
colinmil
Jul 6, 2015 04:03 PM
karbin
Jul 5, 2015 11:37 PM
