Engine pull with trans, transfer case?
Old Jan 25, 2012 | 08:09 PM
jnew911's Avatar
Hey all,
I've got a 1986 4runner and have got everything disconnected and the engine ready to come out. I decided I want to pull the trans with it, and possibly the transfer case. I have seen plenty of guys on hear pulling the engine/trans, but in my searching I can't find anyone plucking the transfer case too. Can it be done? Is it easier to detach the transfer case before? If it helps it is a 22re with 5 speed trans.
Old Jan 27, 2012 | 05:33 PM
SoCal4Running's Avatar
You'd need a high lifting picker and a screw drive to change the motor/trans angle.
Me, I'd just crawl under and unbolt them both. Really only takes like 10 minuets each.
Old Jan 27, 2012 | 05:41 PM
Minnesotayota's Avatar
I agree with SoCal, get under there and pull them out, It will make pulling the motor much easier
Old Jan 27, 2012 | 06:26 PM
aquaprice's Avatar
You also have to do Crazy angles to pull/install them all together. I'll never do it again.
Old Jan 27, 2012 | 07:04 PM
jnew911's Avatar
Thanks guys. I ended up leaving the transfer case in and pulling the engine/trans together, worked great. I'm glad I chose this way that would have sucked if I tried to take the transfer case with it. I started a build thread check it out: jnew911's 1986 4runner build-up thread.
Old Jan 27, 2012 | 07:23 PM
peow130's Avatar
I took all 3 out at the same time when i pulled them out of a 1st gen. Wasn't hard at all, one guy was underneath pulling the trans down to make a steep angle, the other guy jacked the motor up.. simple enough.
Old Jan 28, 2012 | 08:42 AM
scarey's Avatar
Yes, did the same with my 2nd gen 4runner, 3.0. Steep angle, but did all 3 at once. Needed 3 people.
bigjstang
Jun 2, 2025 03:56 PM
skoti89
Jul 6, 2015 07:45 PM
colinmil
Jul 6, 2015 04:03 PM
Jnkml
Jul 6, 2015 01:20 PM
toyoda8488
Jul 5, 2015 10:18 PM
