Ignition hot fuse?
Old Feb 3, 2012 | 07:50 PM
bend's Avatar
Ignition hot fuse?
I'm installing my aux fuse box right now and I need to find a fuse that is hot when the ignition is turned on (I'm using a relay). It has to be in the engine bay. I would check myself but I dont have a battery because I am in the middle of a 3.4 swap. I dont think the headlight or hazard lights are ign hot but what about the charging fuse?
Old Feb 3, 2012 | 08:17 PM
wyoming9's Avatar
Red face
Your doing a wiring harness merge and unable to figure out a ignition switched power source. Why would you need a battery??
How many amps does the new circuit need to draw?? That is the important question.
Are you looking for a switched power supply to energize a relay coil to supply direct battery power to the new fuse block??
Why does it need to be in the engine compartment??
I know just How I would do this but curious to see some other replies.
Old Feb 3, 2012 | 09:08 PM
bend's Avatar
I'm using a relay. So yes it is going to power a relay. I feel like I said that. And I dont have an 88 ewd just TheMonch's body plug pinouts. Simple question. Does the charging fuse go hot on ignition? I dont want to route a power wire into the cab because it would be a pain in the ass. I already have the accessory wires in the engine bay.
Old Feb 4, 2012 | 01:24 AM
wyoming9's Avatar
Red face
Sorry then I am unable to help.
Good Luck
When I ran a extra fuse block I ran the power off the unused rear defroster circuit
As this will not work in your case Because it is inside the cab.
It worked for me but I thought others would have much easier ideas.
Old Feb 4, 2012 | 07:39 AM
Blackulua's Avatar
My EFI fuse used to run hot and would blowout and I would have to replace it every week.I checked my manual and tried retracing the where would the short be but it was so hard to tell.I did a TPS replacement because my timing was off and so far no blowout of fuses and I had to replace the EFI fuse socket with another fuse holder soldered in.
80Truck
Oct 12, 2025 07:25 PM
theking11863
Mar 19, 2016 09:36 PM
bvleonov
Aug 22, 2015 11:39 PM
izzmee
Aug 17, 2015 10:20 AM
rushw
Jul 18, 2015 01:46 PM
