Battery Cable
Old Jan 25, 2012 | 03:12 PM
Bako88's Avatar
Battery Cable
Can anyone recommend a source for replacing old cables?
Old Jan 25, 2012 | 03:16 PM
xxxtreme22r's Avatar
Got mine from Autozone.
Old Jan 25, 2012 | 03:31 PM
Bako88's Avatar
Did they work out good for you, or would you have picked another source if you did it over again?
Old Jan 25, 2012 | 03:33 PM
Mine have been pretty good. I did get a slightly heavier guage.
Just keep in mind since they are "universal" you have to splice in or replace the fusible link wire.
Old Jan 25, 2012 | 03:58 PM
yotarover's Avatar
im buying mine from the welders supply store. cheaper and i know the quality is better, it's cut to length and can be lugged/soldered in store.
Old Jan 25, 2012 | 04:21 PM
mudslinger83's Avatar
Walmart has the universal battery cables
Old Jan 25, 2012 | 06:27 PM
Moonfish's Avatar
One could do that. I did not. The wire does lead to a fuse box.
Old Jan 25, 2012 | 11:32 PM
wyoming9's Avatar
I make all my own out of welding cable. I use crimp on lugs and marine battery terminals These being a stud with a nut great for adding extra wires .
The other ring terminals just go over the post making it easy.
lots of short pieces that can`t be used for anything else.
Bigger in battery cable is always better.
Old Jan 26, 2012 | 03:57 AM
angrybob's Avatar
When I upgraded my alternator, I also did the 'Big 3' mod and found this kit on amazon.com.
For less than $40 I was able to make a 1/0 cable for the long alternator to battery (with an inline 150A fuse), battery to ground, frame to block, and have the amp RCA cables and speaker wire for my radio install. Worked perfectly.
Bourbonblues
Dec 15, 2017 05:43 PM
Williamemslie
14
Oct 5, 2015 09:28 AM
tazman1972
11
Sep 28, 2015 10:32 PM
SCZIG
Sep 20, 2015 09:00 AM
toyotafreak98
Sep 10, 2015 02:57 PM
