alternator issues
Old Jan 24, 2012 | 01:12 PM
Duckie's Avatar
alternator issues
So here is some back story. Finished the TC and got her all timed up and running perfect. I noticed a small oil leak from the area of the top timing cover bolt (the one inside of the head) and got it sealed up. I still had a small drip coming off the bottom, onto the steering stabilizer and figired it was just left from the leak. Turns out it was because I didn't fix the groove in the crank from the original seal. So today I ordered a repair sleeve to fix that.
As to my alt issues, this morning while driving the truck to work (and subsequently slinging oil all over everything under my hood), my brake and charge lights came on. Lights dimmed, ect. I researched it and know its most likely something to do with the alternator, brushes, voltage regulator, and so on. So I only drove her from work to my parents and thats where she is parked until I get the repair sleeve.
I guess my question is, could oil that has covered everything have gotten in the alternator and be causing these issues? I'm going back over later to pull it to have it tested anyways, but I would like to note that the whole bottom on the alternator was covered in oil.
Any opinions are appreciated.
Old Jan 24, 2012 | 02:27 PM
BMcEL's Avatar
It's much more common for the brushes to wear out. I'd open it up and check them...sounds like it's due for a cleaning anyway.
Old Jan 24, 2012 | 02:54 PM
angrybob's Avatar
Personally, my experience is that oil doesn't affect the alternator. I drove my rig for a year before I rebuilt the power steering pump which leaked ps fluid all over it. My guess is also that its the brushes.
Old Jan 24, 2012 | 06:58 PM
87Toy22r's Avatar
Oil can mess with alt!
Old Jan 24, 2012 | 07:13 PM
Duckie's Avatar
So my plan for now is to pick up the repair sleeve tomorrow, and on Thursday I'll go ahead and repair the crankshaft and finish removing the alt for cleaning, inspection, and testing. If it tests bad, oh well ill just buy a refurb. If its good, ill just buy the brushes. Either way ill be taking a look at it before I even take It to get tested.
Old Jan 24, 2012 | 07:33 PM
BMcEL's Avatar
If the brushes are bad, it will test bad. I would NOT recommend trading your OEM alternator for a remanufactured unit. This goes for starters and blower motors too...repair OEM every time.
Unless it got completely saturated with oil, it's probably just the brushes which are only a few dollars at the dealership. I replaced the brushes in mine at about 215k miles and it's still working perfectly at 255k. I wouldn't replace it with a reman if someone handed me one for free.
Edit - Toyota makes updated front and rear main seals that will ride in different spots on the crank. This is a better option than sleeving it.
Old Jan 26, 2012 | 10:29 AM
Duckie's Avatar
Alright guys, a really quick question. Whats the best way to remove the oil seal with out damaging it? I currently have the crank pulley and alt off, and I have my sleeve to install on the pulley. I just wanted to remove the oil seal as well to make sure its not comprimised. (BTW, the oil seal is brand new from my timing chain job, so as far as running, the engine might have about 2 hours of run time with all new timing stuff.)
Old Jan 26, 2012 | 10:40 AM
Duckie's Avatar
Unfortunatly, it is already a re-manned unit. Today when I pulled it I double checked and has a re-man stamp. I have yet to even crack it open but I can already say its pretty well covered in oil. I'll see how much got inside though and make a decision after I get it cleaned up and tested.
Old Jan 26, 2012 | 11:14 AM
Duckie's Avatar
How do these brushes look? From some of the comparative pictures they dont look too bad.
Old Jan 26, 2012 | 11:25 AM
BMcEL's Avatar
They don't look that bad. I personally wouldn't waste my time on a remanufactured unit. If I were you I'd try to find a used OEM alt to put some new brushes in and call it good.
Old Jan 26, 2012 | 12:07 PM
Duckie's Avatar
The only problem with that is that unless an OEM alt can be had today or tomorrow for less than a re-man, its not really an option. I need my truck back up within the next 24 to 48 hours. I'm really hoping that I don't need an alternator at all.
Old Jan 26, 2012 | 01:08 PM
BMcEL's Avatar
You could always clean the alt and all connections, slap it back together and see if it still does it.
Old Jan 26, 2012 | 01:14 PM
ZUK's Avatar
ZUK
Is the charging belt soaked full of oil and slipping? I tend to think your alt is good.
Old Jan 26, 2012 | 01:20 PM
Duckie's Avatar
The alt just tested bad at O'reily. A reman Is $80. I did consider the belts being coated, but now that it tested bad after I cleaned It up Im not sure.
Old Jan 26, 2012 | 01:25 PM
BMcEL's Avatar
Could still be bad connections...I've seen good alts test bad at auto parts stores.
Old Jan 26, 2012 | 02:08 PM
Duckie's Avatar
Well tomorrow I'm going to slap this one back on and see how I goes for a few short drives. If its still bugging ill just drop on a new reman.
Old Jan 26, 2012 | 04:00 PM
angrybob's Avatar
FYI - I'm guessing you are talking about the oil seal that is pressed into the timing cover?
I can't remember for sure if that seal bottoms on the timing cover or if its a through hole, but I think it bottoms and needs to be pulled. If you can tap it through the back side of the cover with a socket or PVC pipe/fitting that is only slightly smaller, than maybe. If it has to be pulled, you probably can't...and more important shouldn't.
Seal is cheap, like $5 at O'Reilly.
Heh - if you're coming to Phoenix I have an extra one you can have
Old Jan 26, 2012 | 05:22 PM
Duckie's Avatar
Thanks for the advice. I wound up just leaving it though. When I first pulled the crank pulley, I thought I saw a mar in the bottom of the seal. Turns out my eyes were blinded by the sun just perfectly coming through a gap by the battery while I was looking up. I wiped it down and it was sitting perfect and new looking still. Looking back, if I really wanted it out, I probably would have just pulled the oil pump.
Old Jan 27, 2012 | 07:08 AM
Duckie's Avatar
A quick question, what brand was the oem alternator? Was it Denso? Because that's the reman I currently have, and those remans look to run closer to $100 online.
Old Jan 27, 2012 | 08:18 AM
bluAM2's Avatar
Denso it is
