Winding noise in transmission.
Old Feb 7, 2012 | 08:00 PM
RylanBegley's Avatar
My 88 Toyota pick up (3L V6 4x4) starting making a strange winding noise when I Push the clutch petal in, would a Clutch pilot bearing be whats causing this? what about a Clutch Release Bearing? Thoughts?
Old Feb 8, 2012 | 01:51 AM
CRamsey's Avatar
Release Bearing
Release bearing is my guess. I just had my transmission replaced and had this addressed as well.
When you push the clutch pedal, the slave cylinder pushes a fork that presses on the release bearing to pull the clutch plates apart. (very basic description) When you release the pedal, the noise goes away, right?
Old Feb 8, 2012 | 08:28 AM
Ya it goes away once I've released the clutch. I have a funny feeling i might just get all the bearings in that area and replace them all at once. No harm in a bunch of new parts, especially since they don't cost that much. I just don't know that much about transmissions soo I figured I'd ask on here.
Old Feb 8, 2012 | 03:26 PM
bmcghie's Avatar
Sounds like a release bearing. If you're not sure... keep driving it. I drove mine for about 3 months from first whine to when the SCREEECHING got really bad. Then I did a clutch job. It's not a rush job, the bearing takes a long time to fail, and you'll feel it get worse in the pedal before it goes.
Old Feb 8, 2012 | 03:28 PM
sebastianholmes's Avatar
you should just replace the whole clutch while youre in there, and maybe a rear engine seal depending on the mileage of your motor
Old Feb 8, 2012 | 05:49 PM
Ya I talked it over with one of my buddy's, we are pretty sure its the Release Bearing, I figured I might as well do pilot bearing while I'm in there, then at work today I was thinking I might as well put a new clutch in while I'm at it so its funny you said that as one of the first things I read when I got home, shes got 208 000 miles so it would probably be worth it, this might just turn into a bigger project then I intended.
Old Feb 8, 2012 | 08:14 PM
Update, Went though the Trucks maintenance history, a clutch was put in 2000 miles ago with no mention of a throw out bearing or pilot. why they didn't do the release and pilot bearing when they were in there is a mystery to me, but I'm not complaining because a new clutch was going to cost me around 270 bones.
Old Feb 8, 2012 | 08:20 PM
Leviticus6432's Avatar
previous owners are awesome lol
Old Feb 9, 2012 | 04:27 PM
bmcghie's Avatar
Seriously, who replaces a clutch and pressure plate and doesn't do the bearings at the same time?! Silly silly, in most cases.
Still, good news on having a newer clutch in there. Good luck with the bearing replacement!
Old Feb 9, 2012 | 05:55 PM
TnYota87's Avatar
clutch sets come with the clutch disc, pressure plate, throwout bearing and alignment tool.. alot of people i sell clutch sets to dont replace anything else other than the parts that come in the kit..
gibbonsballer10
Oct 26, 2023 07:13 AM
4Xtruck
16
Sep 24, 2015 09:38 AM
briholt
Sep 20, 2015 10:26 PM
langry345
Sep 14, 2015 03:36 PM
Streetrod19772000
Sep 10, 2015 06:22 PM
