22re metal rattle noise coming from engine (timing chain?)
Old Sep 15, 2015 | 04:23 PM
gibbonsballer10's Avatar
92 pickup 22re, 100k miles. About a month ago I replaced timing chain, tensioner, metal guides, new water pump and oil pump. A day or two ago i noticed a metal rattle noise coming from the engine in the timing chain area that i never heard before. You can start to hear the noise at around 2k rpms. Anyone have any idea? Listen closely in the videos.
Old Sep 17, 2015 | 03:32 PM
Anyone?
Old Sep 17, 2015 | 04:24 PM
nordicwargod's Avatar
I listened to it twice and I can't tell you what it is. I'm no expert. Now, what I would do is remove the valve cover and look down there. Look at the guides, see if the passenger side one is broke and try to look at the tensioner, see if its pushing against the chain. [I know visibility isn't good] If you can't see much then buy or borrow a bore-scope to look down there into the timing cover. Check out the cover on the passenger side for rubbing marks. Maybe someone else has an idea?
Old Sep 17, 2015 | 04:28 PM
I just replaced the guides and chain and both sprockets. Tensioner is working fine, i checked it today.
Old Sep 17, 2015 | 04:51 PM
When did you "just" do it? If you just fixed it and it just started making noise then you have a strong clue. Did you also do the oil and water pump? I think anyone replying here would say go in there and start looking.
Rule out some things. Take the fan belt off and start it. With the waterpump NOT turning does it still make noise? If it does then move on. Check everything you took apart. My 2 cents
Good luck
Old Sep 17, 2015 | 11:30 PM
wyoming9's Avatar
Red face
Noises can be a funny thing
Pull the valve cover and look . Just what brand parts did you use ??
Lots of poor quality on the market
Loose heat shield some place .
Just had a friend with a strange rattle noise turned out some of the muffler baffles broke loose . Not being able to see anything he found it quite by chance.
Old Sep 18, 2015 | 11:59 AM
punks_is_4x4's Avatar
Check ur pulleys are they moving at all when the truck is on at idle or are they staying in one place I had a noise that drove me crazy for a while found out it was front main seal on my main pulley I only noticed it when I looked at 2 22res running side by side and I looked down at the main one and it seemed "wobbly" had a buddy take a look hard work but glad I did it. Also check if it only happens in gear or load does it happen at idle ? After its heated up or is it just there as soon as the engine is running
Old Oct 24, 2023 | 03:06 PM
Yotalaka's Avatar
Sorry to revive a ridiculously old thread, but I have exactly the same sound coming on consistently at about 2200 rpm whether in neutral or driving. Did you ever figure out what was causing it?
Old Oct 26, 2023 | 07:11 AM
Jimkola's Avatar
YT Community Team
5 Year Member
You’d be better off starting a new thread. Give details on the vehicle, work done, and symptoms. The better quality and details you provide will get you more responses.
Old Oct 26, 2023 | 07:13 AM
Yotalaka's Avatar
You're right. I only replied to this one because it's the exact sound in the video. Thank you 👍🏼
Ichneumon
Sep 27, 2015 04:21 PM
puddlepirate
Jun 30, 2015 05:08 PM
hexrain
Jun 27, 2015 06:17 AM
Taz22R
Jun 21, 2015 04:44 PM
paxanders
Jun 21, 2015 06:29 AM
