Best key blank
Old Feb 1, 2012 | 08:21 PM
silvr6's Avatar
Best key blank
Just got the little piece of key out of the ignition. Thanks to a local locksmith. I have been using a half key for a while. I would like to get some new keys for the pickup. The last couple I have got were flimsy and one even cracked. Are factory key blanks still avaiable from the dealer or anywhere else? I would be nice to get an OEM key that has the Toyota letters embossed in it.
Old Feb 1, 2012 | 08:44 PM
scuba's Avatar
Toyota keys are the only ones I'll use in my ignition. All others I consider inferior metals and not worth my time.
Call your local dealer and ask if they can cut a key. Worst they can do is say "no, your truck is too old."
Old Feb 1, 2012 | 09:11 PM
vital22re's Avatar
totally a bro
every toyota vehicle I own has the steel toyota blanks, even my spares are the steel. (5 vehicles)
Old Feb 1, 2012 | 09:14 PM
Discombobulated's Avatar
I went to the dealer they needed my vin for the match and I do believe you can pay extra for the og Toyota key.
Old Feb 2, 2012 | 07:28 AM
silvr6's Avatar
Plus I think I have the key code. It is a small metal tag with numbers. Is its better to get it cut with the key code or the keys that I am using now?
Old Feb 2, 2012 | 07:30 AM
pholife's Avatar
if you do not have the metal tag with number....I believe the front passenger side door lock has the number engraved there too.....as everybody mentioned, buy only oem toyota keys...
Old Feb 2, 2012 | 07:56 AM
justin_4runner's Avatar
its better to use the key code, u get a better cut then trying to cut it from a key that is worn down i use to work for honda and i would not cut keys from other keys, i would always get the vin and use the key code to cut them, never had a bad cut that way.
Old Mar 3, 2012 | 05:33 PM
silvr6's Avatar
Just got the OEM keys and had them cut with the key code. They checked the key code with the vin and everything matched up. The parts guys are astonished that I still had the original key code tag.
Old Mar 4, 2012 | 05:02 PM
wyoming9's Avatar
Red face
Interesting I have a good friend that is a locksmith and have him do all my lock work.
I use all off the shelf blanks and with all the vehicles I have lock work done I have never had any issues..
Then I guess a locksmith would use a better quality blank then your average key cutter.
To be honest I never thought of Toyota Key blanks.
I wonder how much 25 would cost
83yotastockR
11
Nov 10, 2015 06:54 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
PNW94Runner
Sep 29, 2015 02:55 PM
JamesDINAN
Sep 22, 2015 05:37 AM
JHalcyonM
Sep 14, 2015 01:10 AM
