89 Toyota pickup V6 engine problem!!!! HELP
Old Jan 29, 2012 | 06:15 PM
moanamilia's Avatar
So im guessing the injectors are leaking gas cause i smell it....so thats one problem, BUT another thing is the truck doesnt have any power at all, sometimes when the battery light, and the brake light is off it may have some power, but when its on theirs no power at all..can someone please help me find, and fix this problem, labor prices is to high, i cant pay labor, so i have to fix it myself...i bought this engine second hand from a truck that got rear ended. it has 92,xxx miles on it... Thank you!!
Old Jan 29, 2012 | 07:50 PM
justin_4runner's Avatar
well fix the leaking injectors first and then see if that helps, but im not understanding what u are meaning by ur second part, u are not giving us many details as to whats going on, is it that u dont have power when trying to go, or is the alt bad and u have no power to run things, please clarify what u mean.
also input where ur from in ur name so if someone that lives close and can help will do so.
Old Jan 29, 2012 | 07:55 PM
bmcghie's Avatar
I think we could better help you if you could explain yourself more clearly.
You bought this engine used, then installed it yourself?
How does it start?
How does it run?
Which brake lights? ABS dash warning light, or the actual tail lights?
Have you tried using another battery? Checking the alternator?
Are you sure the fuel EVAP canister lines are hooked up correctly?
We need more clear details of what is going on, please.
Old Jan 30, 2012 | 08:26 AM
moanamilia's Avatar
Thank you everyone for writting back.
My name is Moana, and im from Molokai, Hawai'i.
i was talking about the break and battery lights on the dash, when it goes on the truck does not have power to GO, and when the lights are off, there is some what power to go, but not to much power. yes its a second hand engine that got swapped by my cousin. i bought a new battery. and i played with the alt...the idle is tooo high when the alt is at the right spot for the truck to gain power. the truck starts up good...
Old Jan 30, 2012 | 08:52 AM
Leviticus6432's Avatar
how do you play with an alt? you make it sound like you adjusted it or something?
Old Jan 30, 2012 | 08:53 AM
You don't have a ground wire burnt to a crisp or something do you?
Old Jan 30, 2012 | 07:09 PM
moanamilia's Avatar
yea im adjusting it up and down... could the timing belt be a problem that there is no power?, im not sure it a ground wire is burnt...i really dont know much about this thing...
Old Jan 30, 2012 | 07:11 PM
do compression test and have the alt tested to see if at lower speeds it doesnt give out about 13 volts.
Old Jan 30, 2012 | 07:38 PM
moanamilia's Avatar
how do i test the alt? n what doest it mean if at lower speed??
Old Jan 30, 2012 | 07:40 PM
yotaman85's Avatar
if you are smelling gas, that does not mean you have leaking injectors. when you said "alt" are you possibly refering to the distributer? if so, adjust the timing correctly. there is a hole bunch of how too's on this site..
Old Jan 30, 2012 | 07:45 PM
moanamilia's Avatar
well i looked under the intake, and i could see 1 injectors where it was wet and smelt like gas
Old Jan 30, 2012 | 07:46 PM
moanamilia's Avatar
yea im also refering to the distributor
Old Jan 31, 2012 | 01:29 AM
TNRabbit's Avatar
You need to go here first & read up:
http://www.toyotanation.com/forum/80...e-posting.html
We used to have that post here at YT but can't find the dang thing in the stickies now...
Old Jan 31, 2012 | 10:06 AM
moanamilia's Avatar
Awesome thanks alot!! it was a big help.
well i think i might have some problems setting the timing and all that. :/
Old Jan 31, 2012 | 05:39 PM
moanamilia's Avatar
ok so i took my alt to napas to have it check, and it was still good. but now truck is running with better power, maybe because alt wasnt on good??? because my battery was dead and it was a new battery.
Old Jan 31, 2012 | 11:41 PM
moanamilia's Avatar
Fuel Injectors V6 3.0
Does anyone have a site where i can go for instructions on how to change my fuel injectors for a 89 toyota Pickup V6 3.0?? step by step will be helpful, from taking off the intake and vacuum hoses.
Mahalo (thank you)
Old Feb 1, 2012 | 10:03 AM
scope103's Avatar
http://www.ncttora.com/fsm/index.html
Unfortunately, for the 84-89 manual, you have to download the whole thing. But you NEED a manual; that is where you should go first.
I'm curious; how did you figure out you needed to REPLACE your fuel injectors? An expensive item.
Old Feb 1, 2012 | 11:12 AM
ksti's Avatar
Did you have them checked and cleaned?
Old Feb 1, 2012 | 11:28 AM
ksti's Avatar
I dont know how this post got here Sorry! was supposed to go somewhere else.
Old Feb 1, 2012 | 01:42 PM
moanamilia's Avatar
i took my truck in to a mechanic to have the idle checked out, and he said while walking up to the truck he could smell a strong smell of gas, and he looked under the intake manifold and seen a wet spot around the injectors so he took off the intake manifold and he said that the o rings needed to be replaced, and the spray pin plastic was worned out.. also he said it looked like gas was over flowing from the electrical attachment. and yes it is an expensive item. but a family friend has a spare of injectors so he said i can have it........what shall i do???????? labor is to expensive to pay so i wanna do it myself..:/
