Is there a fuse for the windshield fluid pump?
Old Jan 29, 2012 | 02:49 PM
dlister70's Avatar
I have a 1992 Pickup with a 22re. The windshield wipers won't "mist". I took off the reservoir and the wiring seems fine.. but the pump doesn't sound like it's coming on at all.
The pump is less than a year old, but installed by the previous owner so I can't get a free replacement. I figure it's either a bad pump or an electrical problem.. so I was hoping for a fuse, but I can't find one. I replaced the "wiper" fuse in the cab fuse box, but I'm pretty sure that's just for the wiper motors.
Is there anything else to do besides go buy the part and see if that'll fix it?
Old Jan 29, 2012 | 02:53 PM
angrybob's Avatar
Remove the pump and put 12 volts directly to it (read: carefully hook it directly to your battery). If it works, its the wiring/electrical, if not its the pump. Wiper fuse includes the pump.
Old Jan 29, 2012 | 03:01 PM
dlister70's Avatar
Thanks for the information! I'll give it a shot tomorrow..
Old Jan 30, 2012 | 04:03 AM
rustypigeon's Avatar
The 20amp "wiper" fuse is for both the wipers and the pump motor. check the pump as described above. Also put a multimeter to the wires with the pump switch on to make sure you are getting voltage out to the pump.
sandyota
Feb 4, 2021 11:16 AM
Sep 4, 2015 09:27 AM
rushw
Jul 18, 2015 01:46 PM
msane99
Jul 17, 2015 10:13 AM
voiddweller
Jul 15, 2015 03:56 PM
