timing chain replacement no start (kinda) help!!
so l just replaced the timing chain
(and cover and water pump guides)
put everythign back together
and it wont start
it turns
and catches
but dies immediatly
seemes like it could be fuel related
btu l didn't do any thing to fuel system?
please help
asap
thanks
goat
and it wont start
it turns
and catches
but dies immediatly
please help
asap
thanks
goat
I would say with 99% of these..."I just did the timing chain and it won't start" theads, and there is a lot of them, it due to the timing being off. Double check your cam timing and then make sure your ignitin timing is correct. I bet your 180* off.
Search, there is plenty on the topic, and it will be better for you to read up on the topic and then ask your question.
the bright links are on the dimples
the crankshaft notch was at 0
the square raised bump on the camshaft was on top
the dizzy is in right
it starts right up
runs real smooth sounds good
(no coughing backfiring roughness)
but dies after 5-10 seconds
the starts right up again if l try
seems to me that the cold start injector is firing
and the rest aren't
l've triple checked that everything is plugged in
and trouble shooting pointers or thoughts would be most usefull
searching around some one with the identical problem had the injector ground disconnected
cant find any thign that tells me where that is
thoughts pics pointers?
thanks goat
it starts right up
and the rest aren't
thanks goat
Badger62811
06-26-2015 09:26 PM
