timing chain replacement no start (kinda) help!!
so l just replaced the timing chain
(and cover and water pump guides) put everythign back together and it wont start it turns and catches but dies immediatly seemes like it could be fuel related btu l didn't do any thing to fuel system? please help asap thanks goat |
it's a 22RE
92 |
I would say with 99% of these..."I just did the timing chain and it won't start" theads, and there is a lot of them, it due to the timing being off. Double check your cam timing and then make sure your ignitin timing is correct. I bet your 180* off.
Search, there is plenty on the topic, and it will be better for you to read up on the topic and then ask your question. |
the bright links are on the dimples
the crankshaft notch was at 0 the square raised bump on the camshaft was on top the dizzy is in right it starts right up runs real smooth sounds good (no coughing backfiring roughness) but dies after 5-10 seconds the starts right up again if l try seems to me that the cold start injector is firing and the rest aren't l've triple checked that everything is plugged in and trouble shooting pointers or thoughts would be most usefull searching around some one with the identical problem had the injector ground disconnected cant find any thign that tells me where that is thoughts pics pointers? thanks goat |
you have the boot from the throttle body to the afm hooked up right?
yep
was just about to search around to learn about the afm goat |
turns out the connector to the afm wasn't making good contact
now it starts right up thanks goat |
