PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Fuel line replacement on 88 4runner
  2. Sensor identification
  3. One lug but style for 4 1st and 2nd gen wheels
  4. What is that leaky hos? I want to buy a new one but can't find one.
  5. best wind deflectors for 93 extend cab?
  6. 1987 toyota pick up wiring diagram
  7. That 90's Look
  8. 1986 4runner DLX 5-speed: 22RE bucking/idle drop, esp. when lights turned on and off
  9. 92 4Runner 5 speed maintenance help
  10. Adding A/C to 88 Sr5 with 3.4L conversion questions
  11. 1986 4runner blue interior
  12. 1986 carbed wont idle
  13. Issue with 4x4
  14. 1990 Hilux Headlight wiring
  15. Blower Doesn't work with switch on High
  16. Steering Wheel Replacement?
  17. 1991 4runner cranking, won't start
  18. 86 toyota 4 runner part identification
  19. Runs perfect!!.....heat soak.....won’t stay running
  20. compound high idle issue
  21. Post 3.4 swap Auto tranny - I want it better
  22. Head Gasket need to knows for the hundredth time
  23. finally.
  24. Limp soft topper corners
  25. 1993 T100 valve cover replace
  26. center carrier bearing
  27. '87 door hinge pin kit
  28. Timing adjustment
  29. Valve clacking
  30. Torshen keys
  31. Confused with power lose
  32. considering a cross country trip in my 94 4x4 pickup!
  33. 90 4Runner fan pulleys 3vze
  34. 95 4runner exhaust replacement
  35. fuel system
  36. Raindrops inside driver's cab - WTF
  37. how to remove the antenna base from fender
  38. 3.0L to 3.4L swap...any place in SouthWest that does it?
  39. Hoses ?
  40. On the 22 RE,
  41. 89 22RE Pickup 2WD No start
  42. Is this the knock sensor harness?
  43. Setting Timing Issue
  44. Diagnosis port cover
  45. While we're identifying gaskets
  46. Narrow wheels, wide tires
  47. Steering Extension Placement
  48. 1995 4runner 4wd indicator switch
  49. Requirements to replace rear exhaust side rocker arm?
  50. aisin center cap for front wheel
  51. 94 Runner Vibration at 30< Play in Diff/T-Case
  52. Unknown bolt
  53. Bosal muffler (284001) installation
  54. Can't find a parking brake cable
  55. 86 truck motor mount to frame
  56. What are these two gaskets for?
  57. Toyota EGR Valve Diagnostics/Excellent video
  58. What brand wheels fit my 1990 4runner
  59. '88 22R coolant/gauge sensor location
  60. issues at 15k
  61. 86 22R northeast
  62. Would I be insane to run this motor as is?
  63. Odd Running Hot Issue
  64. Advice for replacing manual transmission on 1990 toyota pickup
  65. should i replace my exhaust valve?
  66. 22re
  67. Another starter Question
  68. Coolant leak from air control valve
  69. 4wd v. Rwd exhaust systems
  70. 93 V6 Auto 4runner no electrics
  71. 1986 4runner hard start issue (video)
  72. #3 cylinder not firing after putting everything back together
  73. Delayed Throttle Response at high Speed
  74. Audio System Amp Wiring
  75. 89 runner 290k suspension refresh
  76. Gas gauge and temp gauge not functioning properly
  77. Where to go for remanufactured transmission?
  78. Stock Axles???
  79. Testing EFI relay / COR
  80. Newbie with 92 4runner egr question
  81. Canback tops freeway speed
  82. Where is the ECU-IG Fuse on a 1994 Pickup
  83. 4-Runner cranks won't start after battery backwards
  84. 1987 Toyota 4x4 load proportioning valve
  85. Aftermarket Clinometers
  86. Vibration while driving
  87. Help, I think truck is in OPEN Circut!
  88. Shaky Power Mirror
  89. wire routing
  90. Crazy Electrical issue 1986 22RE
  91. Soft pedal, drum brakes, etc
  92. How much do you trust your truck
  93. rocker panel trim
  94. Questions:
  95. How much ATF?
  96. Used engines. When to put them to use and when to pass?
  97. Need help tracing electric connections
  98. Door Open tailgate switch bypass
  99. During oil after engine rebuild. What rings should I have gone with?
  100. Timing chain jump or???
  101. How to determine if my head is OEM?
  102. 1995 4Runner 3.0 auto 4wd fires but won't start
  103. so frustrated
  104. windshield trim replacement
  105. Sunroof Won't close
  106. Anyone used Core Shifters (hurst)
  107. 22re exhaust valve stuck open
  108. Little flutter miss at 2200 rpm...
  109. '86 22r carburetor missing vent tube
  110. Intermittent No Start 3vze
  111. Desperately need help with code 52! ive done it all!
  112. Torque converter or bad solenoid?
  113. Could an out of adjustment TPS or Code 11 cause sputtering, loss of power?
  114. Front splash guards
  115. Carbon buildup on one head bolt & threads?
  116. "No Start" '93 Pickup 22RE
  117. Battery and Brake Light stays on
  118. Engine install: mystery wire on 88 Pickup, 22RE
  119. New OEM speedo cable, leave it or lube it?
  120. Engine chirp... possible bad bearing?
  121. Power steering pump specs
  122. Misfire issue, need help
  123. Radiator Cracks
  124. How hard should it be to turn the AC compressor?
  125. GM 3 wire alternator conversion
  126. 22R Cylinder Head - Recommendations needed
  127. radio fuse
  128. Hilux LN106 Gear Shifter / Lever oscillating at 60kmph
  129. no start
  130. fuse block ID
  131. Where to set the timing without using the limp mode 93 pickup 3.0l
  132. 1989 codes - 22 and 51
  133. HELP!!! 92 pickup 3.0 sending unit?!!
  134. Gear Swap
  135. T4R first gen - Hard to shift first, second and reverse.
  136. 1993 toyota pickup overheating issue
  137. torsion bar frame mount
  138. 1988 22RE Timing Chain Replacement
  139. Original stereo re-install
  140. Closed and open loop, mpg
  141. 22rte fuel issue
  142. 2.25" cat back exhaust parts for 3.0L 2wd
  143. 3VZE Engine block ground strap attachment?
  144. Turbo exhaust for 22 rte
  145. 93 4x4 help
  146. 1986 XtraCab Turbo 4x4 5 speed LOADED
  147. 89 4Runner TPS
  148. 1993 Front Shock Bushing & Retainers
  149. Mystery trans?
  150. 22re rough idle and stumbing when held at constant rpm.
  151. Clutch hydraulic hose replacement
  152. selling dilapidated '86 4rnr dlx; fair asking price?
  153. Toyota pickup 1986, Oxygen sensor, what is its original location?
  154. Head Gasket discussion and Fel-Pro answer to slipper plate design
  155. Transfer case locating pin importants??
  156. What engine oil do you use?
  157. Longer shackles for Dakar leaf springs
  158. 1986 4runner 22re distributor signal generator Pick-Up part number?
  159. Mild popping/backfiring upon deceleration after desmogging 22r
  160. Replacing Overdrive light in 86 pickup
  161. 86 4Runner issues
  162. spartan/aussie locker knowledge
  163. 3.0 lacks compression but doesn’t misfire?
  164. Pop, lurching, and loss of power 86 pickup 22r
  165. Noticeable drop - slow to heat up, oil higher that usual
  166. 2nd Gen Rear Bumper Clarification
  167. 22r rebuild kits
  168. 1990 4Runner 4x4
  169. Reverse Signal Wire on an Auto
  170. Frame compatibility
  171. Rear bearing issue
  172. drive shaft compression distance.
  173. 93 truck wheels on a 88 4runner
  174. 86 4runner motor mount specifics 22RE (w56 manual trans)
  175. Just got new 39.5 iroks, how should I go about on the rear tub?
  176. 94 3.0 auto transmission issue
  177. Blazeland Long Travel: Shock Recommendations
  178. OEM number for thernostat on 1989 V6 hilux
  179. Shock recommendations for stock suspension 4x4
  180. temperature sender in toyota truck 86
  181. 5 speed with 22re Sudden Pop Now wobbles
  182. How to tell...
  183. 1987 4Runner
  184. Rebuilt motors vs stock toyota motor
  185. Wiring diagram needed. 1990-1994 pickup or 4Runner.
  186. engine, trans, and transfer case mated together- will it drop in at same time?
  187. High crankcase pressure in newly rebuilt 22RE
  188. Need some opinions on a 94 4runner build
  189. Vacuum / wastegate activated exhaust dump valve / cutout?
  190. Hesitation durring acceleration
  191. High idle 1993 3vze pickup
  192. '91 3VZE idle issue
  193. Trouble shooting.
  194. 1991 3vze Gremlins and wiring
  195. 1989 toyota pickup rear diff issues?
  196. 1989 Weatherstrip Help
  197. 1992 pickup idle air control valve questions.
  198. 86 4runner 22re W56 transmission Fuel Pressure Problems
  199. 1993 t100 suspension upgrade ...
  200. Thermostat
  201. Couple of Questions
  202. '93 3VZE 2WD - Check Light + unknown wire
  203. 3VZE doing a... Not working...
  204. Wiper Linkage Replacement and Timing
  205. Head gasket / Possible Rear Camshaft seal?
  206. 'Injectordyne' 4 hole injector problem
  207. 3 Gang toggle & voltage
  208. CT26 upgrade
  209. rear axle shaft dust plate?
  210. 4Runner Pulls Hard to Right in 4wd
  211. 87 DXL instrument panel
  212. Crank pulley bolt missing
  213. Faclutch Hmmmmmn
  214. fuel pump electrical connector
  215. Turbo
  216. Morning Creaking
  217. 1995 Toyota 4Runner leaking at transfer case adapter
  218. Toyota T100 Door Seals Wanted
  219. 3VZE working A/C compressor wanted
  220. Aluminum Radiator
  221. R150F shifter vibration/kickback
  222. Chirp/ Cricket sound 22re
  223. Repainting/Repairing 4runner Fiberglass Topper
  224. 1995 4runner 3.0 EGR issue, Code 71
  225. Wheel Spacers for Wider Stance?
  226. Front Power Windows not working
  227. Milky way.
  228. 22RE Knock Midrange With No Load
  229. 88' Wiring Harness Replacement Suggestions
  230. 3rd Gen 4Runner LCA's on a 2nd Gen?
  231. Limiting strap mounting
  232. 22r to 3.4 swap help
  233. 2rz 1995 tacoma 5 speed/ losing ign
  234. toyota speedometer mechanical to electronic conversion
  235. Backing plate identification
  236. Fan shroud doesn't exactly fit mounting bracket
  237. Mechanical Gauge Wiring for light
  238. Turbo!
  239. Best link for diagrams & part #s for gaskets, crush washers, bolts for intake stuff
  240. 1995 4Runner 3VZ coolant leak
  241. 92 Toyota PU 3.0 LED Turn Signals
  242. Need to know what's different about my rear suspension
  243. 22-RE needs help. Suffering it is.
  244. Which aftermarket 22re head?
  245. Still Brakes (i.e. really have to press down to get vehicle to stop)
  246. Vacuum advance Unit
  247. T4R first gen - Zuk mod, no cut no weld
  248. 22re “invisible turbo” symptoms
  249. Water bypass?
  250. Poor MPG
