High idle 1993 3vze pickup
Old 09-09-2018, 08:02 PM
I'm sure this question has been posted to this forum before, but I can only search for so long.
One morning a couple weeks ago my idle ran and stayed at 1,500rpm (the idle and rpm were literally perfect before this day), I know once the coolant reaches a certain temperature, the idle should drop down to around 850rpm. There is no check engine light on, but for giggles I checked the code anyways, and all systems are normal. I checked the vacuum lines and even had my mechanic take a quick peak at it, all looked good. I checked the coolant level as my mechanic said a low coolant level can cause a high idle (I forgot the reason). My brother and I did a valve job on the driver side head summer 2017, and while we had it apart we replaced the engine coolant sensor as well as the other switch and sensor located in that same location (I forgot the names). Of course we replaced all the vacuum lines and most of the coolant hoses as well. Then I had the head gasket on the passenger side done just a few months ago. I did adjust the idle screw, which gave me the 850rpm idle, but then I didn't have the high idle, which was fine until this weekend as the temperature is dropping and the mornings are a bit cool now. I'd like to do what I can to figure out the issue before I decide to drop it off at my mechanic, as funds are tight and I don't have an extra vehicle around. Any help and ideas are much appreciated, thank you in advance!
Annaissofab is offline
Old 09-09-2018, 09:07 PM
mholme's Avatar
Mine does this too, seasonally. First sub 60 degree morning in a while and *cold idle is around 1500 RPM. Mine settles back down to the correct warm idle after a few minutes. Are you saying yours just hangs high all the time even after warm?
mholme is offline
Old 09-10-2018, 05:44 AM
Yeah itís been staying high all the time now. This morning on my way to work it stayed at 1,500rpm the entire drive, my drive to work is 20 minutes so thereís plenty of time for my truck to run warm.
travisamorgan
02-12-2016 09:46 AM
dbraun
11-14-2013 08:36 AM
dmahonec
04-30-2012 01:50 PM
FogRunner
10
08-30-2009 05:33 PM
mike_d
11
11-14-2003 06:50 AM
Quick Reply: High idle 1993 3vze pickup
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
