87 DXL instrument panel
Old Sep 4, 2018 | 11:59 AM
Scott Mcgill's Avatar
Hi
1987, DXL, 22RE,
Instrument panel lights stay on: CHARGE, BRAKE, AT oil temp. all stay on when running.
bought new correct battery. Is the alternator going?
Just happened out of nowhere. Starts and runs fine. lights work , rear window works up and down
suggestions?
thanks
SMcG
Old Sep 4, 2018 | 12:38 PM
coryc85's Avatar
Classic symptom of a bad alternator. Could be as simple as the brushes. There are some tests in the Factory Service Manual that will do some basic checks, and visually you can look at the brushes. If possible, try to fix that OEM Alternator (assuming it is OEM).
Old Sep 4, 2018 | 01:21 PM
thanks Cory
thought it might be the aldo. Not sure if its OEM, did swap one out of my 89 SR5 into this 87 DXL. Either way gotta go investigate, thanks. nice ride, mines red also
Old Sep 4, 2018 | 01:28 PM
keycw's Avatar
5 Year Member
had the same symptoms for an 88 dlx some years back, swapped the alt and fixed it up.
Old Sep 4, 2018 | 02:55 PM
thanks keycw
leaning towards the Aldo, tried the Batt as its an easier fix. But, thing was 4 yrs old so, now I'm up to spec.!
Aldo tomorrow.
Old Sep 6, 2018 | 12:53 AM
wyoming9's Avatar
Red face
Get a Multimeter read voltages it might be a poor connection
corroded connection
It is not fun to get a rebuilt Alternator then still have the same problem and a cheap rebuild as well.
Old Sep 6, 2018 | 04:33 AM
thanks, will check wiring, also got another Alt. just in case.
Old Sep 6, 2018 | 01:22 PM
RAD4Runner's Avatar
Battery's about due for replacement at 4 years
Before replacing anything else, verify it is broken and ask yourself, If I replaced it would it fix my problem?
https://www.yotatech.com/forums/f116.../#post52401963
Old Sep 6, 2018 | 01:40 PM
The Alternator was bad. Replaced and lights went off. Battery, after 4 years was probably something that was gonna get me this winter.
Thanks to all.
Old Sep 6, 2018 | 01:46 PM
And to update, the alternator I swapped out of my 89 SR5 back in 2012 was NOT a Denso; it was marked Re-man after removal this morning , and therefore a throwaway. My 1987 dlx rig turned 253,600 btw. 2nd motor, long block from Greg Mahoney in Oregon 2014. Still a great ride to have; my other is clean, original 68 cougar, 289, stick.
Old Sep 6, 2018 | 02:01 PM
wyoming9's Avatar
Red face
What is a Cougar ??
More batteries fail from the heat then cold
Old Sep 10, 2018 | 10:18 AM
jakey poo's Avatar
Originally Posted by wyoming9
What is a Cougar ??
Typically an attractive middle aged woman
Old Sep 10, 2018 | 11:02 AM
Reference made to 1968 Mercury Cougar, the other vehicle I operate.
Old Sep 10, 2018 | 11:04 AM
BTW, this is my Crawler
muril010
Sep 6, 2013 12:06 PM
aviator
Mar 10, 2004 04:48 PM
Jollyradar
Mar 3, 2004 11:38 AM
Supercharged
Feb 17, 2004 06:36 AM
