Timing adjustment
Old Oct 28, 2018 | 10:05 PM
Cesar Telles's Avatar
Timing adjustment
I’m having trouble turning the engine over, just did a head gasket and timing chain, I’m not to sure if my timing of way off because I lost the position it was in originally, maybe that’s a reason why it won’t turn over? If so what is a good basis to set it at so I can get it running to time properly
Old Oct 29, 2018 | 02:19 AM
ev13wt's Avatar
5 Year Member
Distributor, recheckt positon at intake TDC.
Old Oct 29, 2018 | 07:35 AM
Co_94_PU's Avatar
pull the valve cover there is a dowel pin on the cam it should be at the top at twelve o'clock. Crank should be at TDC, zero on the timing marks (or balance pulley key way at twelve o'clock)
Old Oct 29, 2018 | 07:49 AM
scope103's Avatar
Usually, "turn over" means: Turn. Over. Not running, not firing or coughing. Just turning over (powered by the starter).
Is that what you mean? Or is it turning over, but not firing? Is it firing, but not catching? Is it catching, but not running?
If it won't turn over, valve timing is not the issue.
Old Oct 29, 2018 | 07:52 AM
ev13wt's Avatar
5 Year Member
Hmmm. True, op needs to clarify.
OP. Install the starter!
Old Oct 29, 2018 | 10:42 AM
Co_94_PU's Avatar
He has another active thread... With a noise/clacking.. And a valve spring that's compressed...
Old Oct 29, 2018 | 10:50 AM
scope103's Avatar
Ah, yes! https://www.yotatech.com/forums/f116.../#post52411052 He really did mean turn over -- by hand!
broncbob
Nov 24, 2009 12:26 PM
Bob_98SR5
Mar 6, 2006 12:31 AM
CILO
Feb 17, 2006 08:05 AM
AllCammedUp
Jul 28, 2003 02:04 PM
Ava
7
Apr 28, 2003 08:29 PM
