94 Runner Vibration at 30< Play in Diff/T-Case
So I just picked up this runner a few days ago. When I picked it up there was vibration. The guy thought the tire (front pass) needed to be balanced. I did that, but nothing. Went underneath, shook the steering components and noticed the idler arm is very loose. 30 mins later and found out it wasn't the idler arm (due to replacing it) and all steering components were tight. Out of researching this and many other forums, I headed to the drive shaft sure that it was the U-joints. Shaking the crap out of that, I did notice the U-joints were loose and there was some play. I purchased three new moogs. Additionally, there was a lot of play where the rear driveshaft bolts to the T-case (on T-case side past the U-joint). I am thinking now that my outer transfer case bearing is bad and it will need to be replaced. I have a hunting trip coming up next weekend and need to get this done by then. I have looked up videos and have seen everything from people removing the seal and doing work there to dropping the transfer case and tearing into it. What would you all suggest would be the easiest approach?
94 runner 3.0 4wd
All help and comments are appreciated. Thank you.
94 runner 3.0 4wd
This has happened to me. At first I thought it was the rear bearing, but the nut was simply loose. I also dropped the tiny bb into the case changing that bearing, the one that hold the speedo giver from turing on the shaft. It can be done with the tcase in the truck.
After I replaced the bearing, it was still there. Replaced ujoints. Still there, but less.
The vibration that was left was most noticeable going from throttle to engine braking and back again. Right through the "middle" = vrrrrrrrrt
This culprit was the rear diff pinion bearings.
The entire thing starts, I think, when the leafs flatten out. This gives you a pinion angle that always vibrates, even more so if you fix the sag with extended shakles.
I definitely notice it more when I go from throttle to engine braking and back. I guess I better start looking at how to replace the pinion bearing. I will replace the U-joints tonight and hopefully have it finished and check after that to see how bad the vibration is and if I can live with it for a month or so. Did you just replace your pinion bearing or did you rebuild the whole diff? Thank you for the info. It is much appreciated.
Quick 3rd swap is what I did.
I really want to learn to setup diffs. I have watched all the vids and now have one to play with, since I put a used one into my truck.
Bad pinion bearing, should move like your tcase output
This is awesome information! I will be checking out these videos later as I am going to need this wisdom to tackle this project. Getting ready to start my lunch break now. going to run home and try to turn the wrench a few times and maybe drop the drive shaft before I have to be back.
Dropped the driveshaft last night. Both Ujoints were shot and the nut going to the rear t-case shaft was very very loose. Checked the pinion bearing and it still seems nice and snug *fingers crossed*. Once I figure out how to add this forum to my phone, I will upload pics of the Ujoints. Thank you so much for your help.
Cross your fingers, but it will probably hold (and not vibrate that bad) for the time you need to get new 3rds
And Marlins Tcase rebuild kit. Tcase rebuilding is nothing hard, just need a press, some creativity for tooling and some pullers. And an angle grinder for the really "close to gear" bearings
I will definitely do that. I found a Tcase for a hundred bucks on CL that I am picking up and will rebuild that one. Question though. I have decent mechanic experience and have done a lot when it comes to the engine bay and everything inside. But I have never heard of 3rds...What is it? haha
Gotcha. Makes sense lol. Well I got everything back on tonight. There is no play in anything and everything torqued to specs. Overall it is much better. I still do have that vibration between 50 and 60 though. I’m going to get it aligned and go from there. Thanks a lot for the help. I will be looking for the best thing that is in poor shape and start rebuilding that to get ahead of the game.
vasinvictor
Sep 27, 2012 06:24 PM
Davidclark311
Dec 13, 2009 09:16 AM
