Engine chirp... possible bad bearing?
Old 10-02-2018, 03:35 AM
Not sure if any of you have experienced this or know the culprit... sound is heard through all gears while accelerating and when pulling the throttle cable in neutral. Iíve been told it could be a bad bearing. The engine was rebuilt but Iím not sure to what extent or how long ago and way too much silicon was used on reassembly however Iíve taken the valve cover off and everything seems to be ok, lots of oil everywhere, not burning any, slight glaze of oil around the pan and thatís about it. I have yet to redo timing since installing the Weber and recently purchased feeler gauges to check valve clearances.
87 pickup 4x4
dirtcorecockler is offline
Old 10-02-2018, 02:50 PM
Could be rod knock. Pull one plug wire off at a time and see if it stops making the sounds. Could be timing knock too if your timing is way out of wack. Check engine oil for fine metal shavings.
superex87 is offline
The following users liked this post:
dirtcorecockler (10-02-2018)
Old 10-02-2018, 03:30 PM
Will do thanks. I was unsure because itís very loud when Iím in 1-3 gears, get a lot of rubber necking, and itís got such a high note chirp rather than a knock I thought was associated with rods/bearings. Also the sound has been going on for a while, I bought it in May this year and has gotten a little worse over time since I initially thought it was pulley or clutch related. But now itís very constant, doesnít seem to get worse or better with sea foam, Lucas, or Metal Lube. Iíve pulled the belts and sound still goes and had an Aisin clutch kit installed only 2k miles ago.
Old 10-02-2018, 05:53 PM
Mechanics stethoscope, long screwdriver, wooden dowel... Just about anything solid you can press against various bits if the engine while keeping your head out of the danger zone..
Don't guess where the sound is, listen and it will tell you.
Co_94_PU is online now
dirtcorecockler (10-03-2018)
85yota_prerunner
7
01-14-2015 10:56 AM
Up&Down
03-21-2014 05:28 AM
ato178028
10
06-13-2009 05:34 AM
SuaveGato
08-30-2006 03:16 PM
kdeking
9
11-24-2002 03:57 AM
Quick Reply: Engine chirp... possible bad bearing?
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
