GM 3 wire alternator conversion
Old Sep 29, 2018 | 03:59 PM
SteveH1957's Avatar
1986 sr5 with charge gauge and light.
# 1 wire to yellow #1 alt light yellow . start engine
Light goes off but not charging. So
I changed from yellow to red wire on #1
now charging but light stays on. Whats wrong
Thanks Steve.Sense to #2
Old Sep 30, 2018 | 03:51 AM
keycw's Avatar
5 Year Member
is it a new alternator?
Old Sep 30, 2018 | 06:18 PM
SteveH1957's Avatar
No But had it tested and tested good?
Old Sep 30, 2018 | 07:01 PM
scope103's Avatar
So far as I can tell, your vehicle has to be (has to have been) rewired to use the dash light with a "3-wire" (CS130?) alternator.
The field wire on the CS130 is "#1", and should be connected to the (originally) red wire to the Engine Fuse. The (smaller) white wire is the Sense wire, so it would go to #2.
The yellow wire goes to battery voltage through the Alt light. It's purpose is to connect to the alternator output, so that when the alternator reaches 12v, the alt light has 12v on both leads, and goes out. According to this site https://www.pirate4x4.com/tech/billavista/Wiring/Part2/, you could use the yellow wire instead of the red wire to #1 to supply the field current. If you did that, of course, the Alt light would STAY ON when the alternator is running. (absent some rewiring).
What alternator do you have? Has your truck been re-wired to accommodate it? (and if so, how?) What voltage did you get at the battery when you concluded "it wasn't charging." (You used your multimeter, didn't you?)
Old Sep 30, 2018 | 07:25 PM
SteveH1957's Avatar
I am getting 14.4 at the battery and same at dash gauge , Light is on I have red wire to # 1 and white to #2 that is the only rewiring done so far, With the yeoole wire not connected
the choke wire is dead. When I had the yellow wire to #1 no light but did not charge. Which way would you hook it up. I thought about using a relay to the yellow wire.
Old Sep 30, 2018 | 07:27 PM
SteveH1957's Avatar
alternator is a 12 SI
Old Sep 30, 2018 | 07:29 PM
SteveH1957's Avatar
Also read somthing about running #2 directly to post on the back of the alternator ?
Old Sep 30, 2018 | 07:33 PM
SteveH1957's Avatar
Alternator is off of my 1979 454
Old Sep 30, 2018 | 07:34 PM
SteveH1957's Avatar
Multi meter yes 12.5
liveoffroad
612
Apr 17, 2024 02:53 AM
dntsdad
3.4 Swaps
59
Oct 15, 2021 04:17 AM
Terrys87
2310
Nov 4, 2015 09:37 AM
Yoda
Mar 5, 2004 07:20 AM
stretch786
Nov 4, 2002 09:40 PM
