3 Gang toggle & voltage
Old Sep 4, 2018 | 03:35 PM
Justin662's Avatar
The lights on the voltage reads no matter if the key is on or off & matches up with my fluke meter , there a blue lights behind each toggle switch when flipped on .
I actually relocated my air conditioner vent , I had to trim down the old vent location about half a inch along the bottom dash piece to fit all the toggles in nice and tight , the bottom of the bracket will be sanded down to make it as flush as possible .
well I finally installed my 3 gang toggle , I actually think this is a great addition to my daily driver (86 4Runner ) ; my 3 switches will be for my front light cubes & bars , back up light bars and a set of rocks lights . It’s actually a lot better quality for only being 30$ on Amazon , I’m surprised that the bracket for it is metal . Great buy and addition .
Old Sep 4, 2018 | 04:44 PM
dropzone's Avatar
Fossilized
what's that wiring running from the toe kick to between the 2 pieces of diamond plate on the door?
Old Sep 4, 2018 | 05:01 PM
Justin662's Avatar
Speakers , they’re from awhile ago I just haven’t cleaned up the wiring , I’ll be putting new door panels that don’t look like crap.
Old Sep 4, 2018 | 11:30 PM
wyoming9's Avatar
Red face
If your voltmeter is on all the time it is wired to a always hot power supply !!
Might be direct to the battery .
Did you install this Aftermarket switch panel?
Just what kind of loads do those switches control
Circuit protection for the incoming voltage and the loads ??
Old Sep 5, 2018 | 11:23 AM
Justin662's Avatar
It’s on all the time purposely, they will control 3 different light setups on the front , rear and under the truck & they will have individual fuses & the main main hit wire has a decent fuse .
Old Sep 5, 2018 | 11:46 AM
wyoming9's Avatar
Red face
Missed something I guess I thought you were asking why it was always on
Just what were you asking??
ryancobryan
Jan 3, 2017 09:19 AM
