YotaTech Forums
-   86-95 Trucks & 4Runners (https://www.yotatech.com/forums/f116/)
-   -   3 Gang toggle & voltage (https://www.yotatech.com/forums/f116/3-gang-toggle-voltage-305577/)
Justin662 09-04-2018 03:35 PM
https://cimg4.ibsrv.net/gimg/www.yot...98146a32e.jpeg
The lights on the voltage reads no matter if the key is on or off & matches up with my fluke meter , there a blue lights behind each toggle switch when flipped on .
https://cimg3.ibsrv.net/gimg/www.yot...9726042d5.jpeg
I actually relocated my air conditioner vent , I had to trim down the old vent location about half a inch along the bottom dash piece to fit all the toggles in nice and tight , the bottom of the bracket will be sanded down to make it as flush as possible .
well I finally installed my 3 gang toggle , I actually think this is a great addition to my daily driver (86 4Runner ) ; my 3 switches will be for my front light cubes & bars , back up light bars and a set of rocks lights . It’s actually a lot better quality for only being 30$ on Amazon , I’m surprised that the bracket for it is metal . Great buy and addition .
dropzone 09-04-2018 04:44 PM
what's that wiring running from the toe kick to between the 2 pieces of diamond plate on the door?
Justin662 09-04-2018 05:01 PM
Speakers , they’re from awhile ago I just haven’t cleaned up the wiring , I’ll be putting new door panels that don’t look like crap.
wyoming9 09-04-2018 11:30 PM
If your voltmeter is on all the time it is wired to a always hot power supply !!
Might be direct to the battery .
Did you install this Aftermarket switch panel?
Just what kind of loads do those switches control
Circuit protection for the incoming voltage and the loads ??
Justin662 09-05-2018 11:23 AM
It’s on all the time purposely, they will control 3 different light setups on the front , rear and under the truck & they will have individual fuses & the main main hit wire has a decent fuse .
wyoming9 09-05-2018 11:46 AM
Missed something I guess I thought you were asking why it was always on
Just what were you asking??
