Wiper Linkage Replacement and Timing
Old Sep 5, 2018 | 06:46 PM
kapeket's Avatar
Hey howdy all.
92 T4R. I removed and replaced all linkage and motor for the wipers.
Didn't think about the positioning. Anyone know why when the wipers stop, they go lower before setting in?
Seems like the one wiper on passenger side wants to settle below the window but if I put it higher, the driver side is not completely down.
Any ideas?
Old Sep 6, 2018 | 12:49 AM
wyoming9's Avatar
Red face
The wiper motor is wired to return to the docking position when the switch is shut off .
if it was not wipers would stop when the switch was turned off
Adjust the wipers by pulling them off and putting them in the correct position .
Old Sep 6, 2018 | 04:33 PM
kapeket's Avatar
Hey hey. Yeah, I've done the cycle and moved the arms to the lowest possible, rational position but once I fire them up, the wipers actually go below the window line and back up.
I'll have to remove all linkage and see if something is off. It'll be a 15 minute job to pull it.
Thanks wyoming.
Old Sep 6, 2018 | 11:28 PM
wyoming9's Avatar
Red face
It sounds like you are installing them to low
Then the arms return to the park position
The only adjustments I have ever made are at the wipers.
In this day quite possible you got the wrong parts which is causing your issue.
How did yours get so bad everything needed replaced ? You did compare the old with the new ?
Old Nov 13, 2018 | 02:03 PM
BlackPearl808's Avatar
Did you work this out, kapeket? I'm having similar issues as I replaced the linkage in minesone from my parts truck which is also an '89. I compared with the other one and it looked similar except the joints in the old one looked a little more enclosed. The reason I replaced it was the old one's was missing a plastic piece at the joint connecting to the motor which caused it to jump a little during operation. Now I can't seem to get it in the right spot..it's not so off that it's going off the windshield but I just want it to be where the engineers intended it to be
Old Nov 13, 2018 | 04:58 PM
amamike91's Avatar
This is where the wipers are on my 90 x-cab if you need an example. Never been off.
Old Nov 13, 2018 | 05:50 PM
kapeket's Avatar
Negative. I still have to all but manually "tap" it into position with the wiper control.
My next effort involves running it outside the vehicle and watching this system work in full view.
I'll update this thread with video and/or images once I figure it out. =)
Old Nov 18, 2018 | 10:46 AM
Thanks guys!
Old May 20, 2025 | 04:22 AM
mudwarrior88's Avatar
I had the same issue on my 93 xcab. The previous owner replaced linkage and said he replaced it with a standard cab set. I too tried messing with the blade location but to no avail. It ended up being the motor linkage clocking. Steps I took to correct:
  1. I opened the hood
  2. watched the wipers cycle a few times
  3. made a mark with tape of where the linkage was at when the blades were where I thought they should be
  4. then shut of the wipers (let them stop on their own)
  5. detached bolt connecting the motor to the linkage
  6. Re-clocked the linkage to my mark and reattach bolt.
worked like a charm.
shafner30
Jan 14, 2015 08:59 AM
shafner30
Sep 16, 2012 03:27 AM
chevylow88
Oct 25, 2011 02:15 AM
desert-rat660
Aug 7, 2010 07:29 PM
Yoda
Dec 24, 2006 08:14 AM
