Rear bearing issue
Old Sep 14, 2018 | 05:38 PM
keycw's Avatar
5 Year Member
Rear bearing issue
so I picked up some longfields, grabbed a rear wheel bearing kit as well. I don’t have a press so I took the new shafts and my old shafts with the bearing/brakes on it to a shop in town that said they had the Toyota bearing tool. Get them back, looks good. Go to install into truck tonight and after bolting the backing plate to the axle housing, if I turn the axle it grinds. If I unbolt it, no grindind and spins freely. 1987 4Runner, factory rear axle no mods other than FJ60 wheel cylinders and a v6 3rd. I am assuming the bearing was installed incorrectly but the snap ring is on and the collar is there so I have no clue. Any help please.
Old Sep 14, 2018 | 09:43 PM
millball's Avatar
Did you determine that the old and the new axles are exactly the same length from where the bearing seats to the axle spline end??
I've heard of some aftermarket axles that need to be shortened a smidge.
Old Sep 15, 2018 | 02:09 AM
keycw's Avatar
5 Year Member
yes axles are the same, I know the Yukon’s have to be cut but longfields are a direct bolt in.
Old Sep 15, 2018 | 04:16 AM
keycw's Avatar
5 Year Member
This is an attempt to upload a short video clip of the issue
Old Sep 15, 2018 | 06:11 AM
keycw's Avatar
5 Year Member
Small update, upon close inspection I noticed the outer wheel seals are not seated all the way (notice in above picture) . I think this may be linked to the issue.
highonpottery
Aug 15, 2013 10:20 AM
94runner4RJ
Jul 26, 2009 11:09 PM
marcus p
Jun 25, 2009 11:32 AM
RallyRoach
Apr 1, 2007 10:41 AM
BOSTON4RUNNER
11
Sep 13, 2005 04:12 PM
