Reverse Signal Wire on an Auto
Old Sep 15, 2018 | 12:12 PM
NMDesertRat's Avatar
Hi everyone,
I recently built up a car computer using a raspberry pi and Crankshaft Android Auto Build. I am getting ready to install a rear view camera in my 86 4Runner. I want it to auto-trigger the GPIO to swtich from the standard android auto screen to the rear camera view. I'll be using a 12v relay to trigger the GPIO, but I would like to tie the relay into the actual reverse trigger wire on the transmission instead of the rear lights. This way I can shorten the run of wires to the between the GPIO and Relay.
It's an automatic transmission and I'm sure it has a trigger wire that tells the system to turn on the reverse lights. But where is it? Anyone know? I assume it's near the transmission bell housing, possibly even near the floor shifter itself, but I don't want to go stripping wires willy-nilly just to check for voltage readings.
Thanks in advance! No Field Service Manual here.
Old Sep 15, 2018 | 02:01 PM
wyoming9's Avatar
Red face
Not a Automatic Person but it should be aswitch in the transmission with one Red Wire one Red /Blue strip
Asa guess it is in the transmission plug called N-1 pins 5 and 14
Squiddy
Oct 27, 2010 06:24 PM
LUV24BY
Oct 14, 2007 11:33 AM
Dekri
Jun 23, 2005 03:35 AM
