Another starter Question
Old Oct 20, 2018 | 01:48 PM
lastcall's Avatar
1990 4x4 Auto T4r 3VZ. For quite some time when attempting to start the engine there would be a clicking and after a few attempts the starter would finally engage; however, now the starter will no longer engage. I am about to tackle removing the starter when I noticed a single female connector that does not appear to be attached to anything. I pulled out the shop manual and in section ST page 4 in item 2 it mentions removing the main battery cable and 'the other'. from terminal 50. I am not clear but it appears it would be in reference to the 22enge than the 3VZ but thought before taking what appears to be a labor intensive task I would check in with more experienced member's for advice.
Comments/Suggestions appreciated:
dave
Old Oct 20, 2018 | 02:29 PM
scope103's Avatar
Page ST-3, item 2 http://web.archive.org/web/201102051...g/1starter.pdf
(Almost) all starters have a main battery cable (heavy, direct to battery w/o any fuses), and a solenoid wire (about 18ga, so much thinner). The solenoid wire is "the other" wire. You have to disconnect them both to remove the starter.
If the solenoid wire ("the other") is disconnected, you won't get a click or anything else. So I'm guessing that's NOT the disconnected connector YOU are seeing. WE can't see it; without a clear photo and good description (location, wire colors, etc.) I don't think anyone can help you.
jonnyboy99
Sep 16, 2012 06:13 PM
redneckandy
Nov 17, 2009 05:25 PM
Stogieguy
Jul 28, 2007 10:41 PM
pfbmgd
11
Jul 20, 2007 04:57 PM
toyotablue
Nov 12, 2003 09:09 AM
