PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. air mass flow meters for 4 cylinders and 6 cylinders
  2. replacement radiator
  3. Correct plug for TE1 & E1 terminals?
  4. Front range offroad
  5. 88 4runner TCase leak?
  6. 3VZ Starts Then Dies
  7. 95 3vze won’t stay idling
  8. I’m new to 22R and having some electrical issues
  9. Terrible Fuel Economy
  10. AFM code but runs fine
  11. 87 22re pickup w/ chinook camper. Help!
  12. 1988 Pickup Power Steering Pump Rebuild Procedure (VIDEO)
  13. 1988 Pickup Transmission & Transfer case removal and replacement Video
  14. Engine starts and dies code 13
  15. Help ID wire location please! Alternator?
  16. Drivers side front wheel extremely hot and causing car to pull left after long drive
  17. New driveshaft I ordered is too short
  18. 95 4Runner Window motors in a 98
  19. Heater core O-ring source
  20. 88 4runner window weatherstripping
  21. 3vze vibration when accelerating
  22. Leakdown testing questions
  23. 22RE bogging down.
  24. Can a bad heat sensor cause chronic high idle?
  25. What I this on my swway bar link spline?
  26. Good first mod
  27. 1986 Pickup - 22R No Spark
  28. 22RE no start ECU pinout?
  29. check engine light on with Key out/off...won't start
  30. 3VZE - hard start and surging engine at idle
  31. 90 4runner 3vze stalls after starting when warm, starts and runs fine when cold
  32. igniton timing not advancing..
  33. 89 3vze brake master cylinder rebuild kit part# help
  34. Timing Off - Overtorqued Cam Bolt?? HELP!!!
  35. 1995 4Runner v6 searching for input
  36. 1986 Toyota Pickup Alternator HOT, fusible link wire HOT---beyond parasitic draw prob
  37. Caster
  38. Anyone replaced tailgate window *inner* weatherstrip?
  39. Throttle body will not come off.
  40. Possible diagnoses/differential for high pitch whine
  41. frame
  42. Can't find my amp
  43. My 93 yota
  44. 1990 4Runner 22RE low oil pressure
  45. 1990-1995 22re truck/4R FSM Question
  46. 22R Ignition Fuse...How many Volts?
  47. Can anyone identify this noise
  48. 1989 22r no spark igniter wiring
  49. 22R intermittent idle issue
  50. 1986 Toyota SR5 Front End Problems
  51. 95 4Runner - Where can I find this darn union-nut elbow for the trans cooler line??
  52. 89-95 Toyota pickup factory graphics options?
  53. 1993 22RE 4WD W56 (Oil Pan Gasket Replacement)
  54. AC Compressor Pulley won't line up
  55. Non-OEM Brake Boosters?
  56. '93 4Runner Coolant Issue
  57. 92 3.0 VZE Crankshaft help
  58. 22R bored out, using oil
  59. Egr delete
  60. Source for tailgate window regulator?
  61. Obd0 or just obd
  62. 22R-E rockers hitting valve cover
  63. Insurance question on an older (1992) Toyota Pickup
  64. 1991 Pickup Brakes Locking Up
  65. TRD Beadlocker Rims on 89-95 4WD Pickup ( Will they fit?)
  66. Surging help, ‘95 3.0
  67. overtightened timing cover bolt and broke off piece of the cast iron block
  68. Machine Shop Needed for 1989 4Runner v6 3.0
  69. 1993 Toyota Pickup Speed Sensor?
  70. Second gen 4runner tailpipe on first gen v6
  71. Won't stay running.
  72. What company makes the BEST rebuilt 22RE engines
  73. How to remove door handle bezel?
  74. 93’ T100 Exhaust
  75. 22re a/c diagram?
  76. 1993 4runner 3.slow Won't start, can't shift out of park, no dash lights.
  77. Need help with fuel hanger
  78. Does my new pitman arm look okay?
  79. dash gauges / blower not working
  80. 22RE can’t idle when cold
  81. corroded taillight bulbs
  82. Horrible Gas Mileage on 1991 Toyota Pickup v6 3vze
  83. Rebuilt 22RE engine question
  84. 22re timing chain replacement average cost 2023/4
  85. Distributor Whiring/Clicking noise
  86. ISO - Fuel Door Cushions
  87. Throttle body sticking when engine is running
  88. Coolant leak back of intake?
  89. need bed skirt panel, 88 pickup
  90. Climate control panel bulb s14w
  91. 3.0 getting slower over a few months
  92. 1988 xtracab - Luna
  93. 89 4Runner Tailgate Window Motor (yay)
  94. 1986 Toyota Pickup Brake Help
  95. Gen1 4runner New Suspension
  96. Body shake with top removed?
  97. Tail light fuse blows when headlights are switched on.ights are tur
  98. valves/timing chain status check
  99. 1988 4Runner | EGR/Air Injection Delete
  100. 1995 Toyota T100 3.4L V6 falling on its face when accelerating
  101. Random plug under radio 94 4wd
  102. Help me settle my idle
  103. Help me settle my idle
  104. Another Alternator Not Charging
  105. Hood support adhesive
  106. 22re idle set
  107. A/C compressor doesn't fit.
  108. 1986 Toyota 2wd Pickup--Parasitic Drain/Battery Keeps Dying
  109. FREE Hood Strut Kit (90-95 4Runner/89-95 pickup)
  110. Steering box adjustment?
  111. Mystery Part off an 88 4Runner Rubber cap with Snaps
  112. Emergency help - out of state and stuck tracing new gremlins
  113. 1995 Toyota pickup 2WD rear lift
  114. Help with shifter bushing replacement for automatic transmission in '86 truck
  115. Help!!! 1989 Pickup has trouble on cold starts
  116. intermittent blower.
  117. AC Not Engaging
  118. 89 pickup 22re runs way to lean
  119. '92 OME upgrade riding HORRIBLY rough
  120. Fuel Smell in Cabin
  121. G52 transmission rebuild question
  122. Pitman arm and power steering box
  123. Air Flow Meter - No longer available
  124. FP pin on circuit opening relay burnt
  125. 95 4runner dash to 95 Pickup.. does it mount up?
  126. 1994 Toyota 4 Runner No Spark
  127. W46 housing shift lever
  128. Dreaded Code 52 3vze
  129. What is this sorry-looking connector?
  130. Valve adjustment 1993 4x4 with 22re
  131. 94 4Runner 3VZE Chassis Engine Perches
  132. 22r was running great but now stalls at red lights??
  133. Help ID this part
  134. Vacuum gauge oscillates rapidly, weak springs suspected
  135. Rattle/marble sound
  136. 94 4runner
  137. W56 Transmission Rebuild Questions
  138. Swapping rear seatbelts for front seatbelts? ('94 extended cab 4x4)
  139. 2nd gen linear clutch spring mod
  140. Weird misfire sound 94runner 3vze
  141. 94 pickup 22re manual compressor clutch stays engaged
  142. 1986 Hilux Timing advance replacement
  143. 22RE cranks but won’t start.
  144. I swapped my Fuel Injectors on my 1992 Toyota Pickup 22re and now it won't start
  145. O/D Sensor / Tranny Code Question
  146. 3vze high oil pressure after rebuild
  147. 89 Toyota pickup Knocking/ticking
  148. Rear suspension woes
  149. Passenger Side Courtesy Light On my 2nd Gen 4Runner
  150. Manual add
  151. Anyone retrofit a 2nd gen 4Runner factory spare tire carrier onto 1st gen 4Runner
  152. U-Joint for Front transfer Case Flange (Auto)
  153. 1995 4Runner total rebuild
  154. 1986 Pickup 22R Throttle Sticking
  155. Water pump oil cooler hose barb
  156. 1991 Pick up 4x4.. No power after 40mph
  157. 1995 PU AC conversion from R12 to R134a
  158. 1 piece driveshaft on an Xtracab folks chime in
  159. ‘95 fuel smell?
  160. Ignition cylinder issue
  161. Will a 285/70/17 spare tire hang and fit in the factory location
  162. Half Moon plugs source for aftermarket head
  163. Bond Cable = Ground?
  164. 22r choke question
  165. 88 22RE Testing ECU
  166. 1989 4runner - Identifying Front End Parts
  167. 1st Gen 4runner Rear Suspension Upgrade
  168. Bad gas milage,bad overdrive, overcooling
  169. Modifying Shocks to Fit Truck Bolts
  170. 1986 Toyota truck need local mechanic in Bay area CA
  171. R150 hard to get into 2nd
  172. 3.0 Randomly Stalls while driving and turning on Headlights..
  173. Need a rear bumper
  174. Crank No Start
  175. 1995 Toyota Pickup tires, bushings, shocks, etc
  176. Door hinge seam sealer
  177. 93 Pickup - Front Shocks Hitting Bump Stop
  178. Help with bell-housing question.
  179. Mystery comonent on the back of late model gauge clusters?
  180. Shopping for a good Airflow Meter
  181. Repairing 5" long Crack In 22R Block
  182. 1989 22re power loss
  183. Help identifying this part
  184. Knock Sensor
  185. wiring / starting problem
  186. I may have just bought a T-Case I cannot use... :O
  187. Installing New Headliner
  188. Can Fuel Pressure be taken at fuel regulator?
  189. alternator woes, 1988 4runner
  190. 94 Pickup Burns Gas/Loss of Power
  191. 87 pickup rough idle when warm
  192. Engine compartment hose sizes
  193. 1990 Toyota pickup 2wd 4speed cel when let off gas
  194. Help with a factory accessory
  195. Adjusting your TPS with a Timing Light-22RE#/3VZE
  196. '93 pickup parking brake part numbers?
  197. 88 vs 89 3vze heater hose kit
  198. Steering Issue Diagnosis Help - New Steering Gear?
  199. VIN swap? 94 pickup comes back 4Runner
  200. Shameless Plug (Living in my Toyota Pickup Video Series)
  201. Need interpretation of fuel system test results
  202. How to do a LIGHT re-torque on head?
  203. What’s your experience with the 3.4 5vze swap in 1st gen 4Runner ?
  204. Heater not working help
  205. 1993 V6 4runner with auto trans not shifting properly
  206. 1993 SR5 4x4 No Brake Lights
  207. o2 sensor weirdness
  208. 93 pick-up 22re starts, runs for 2 minutes, dies
  209. Quality Replacement front bumper - 1st Gen 4Runner
  210. Yet another weird idle issue.
  211. 89 4runner 3.0 Dead, What Now
  212. Dragging & pulling to the right after uphill acceleration
  213. Toyota Pickup 1993 Starting problem.
  214. Rich running. How to lean out?
  215. PSC hydro assist
  216. Torsion bar bolts.... FROM HELL!
  217. Ignition switch?
  218. Engines that will drop into a 1992 Toyota SR5 pickup with 4X4
  219. 89 3VZ Won't Crank
  220. Heavy Duty Battery Cables
  221. Coolant leak at rear of engine (22RE)
  222. help with installing tilt steering
  223. How to get a switch to dim with the dimmer circuit?
  224. Master cylinder differences?
  225. 88 pickup seat belt retractor annoyance
  226. Engine swap
  227. Coolant in Oil. Assumed timing chain cover wear.
  228. Automatic Trans takes too long to shift
  229. Using 2nd gen Tacoma mud flaps on an 86 4x4
  230. Flashing CEL 1993 Pickup M/T 4WD
  231. 22RE--> Jaguar alternator
  232. 3vze Headgasket Job Tips/Info
  233. Air intake system
  234. 22RE No Start
  235. VST-012 vs. 90910-12073
  236. hood coming unglued from inner hood frame
  237. PCV valve has oil running through it!
  238. Lack of power 1983 2wd
  239. ECM main relay Hotwire?
  240. Help! 22re code 27 and 71
  241. Need an ID on Speaker Wiring Plugs
  242. ‘95 seized caliper mystery
  243. Hood Insulation Pad for 89 Pickup? (paint cracking)
  244. Engine ticking from driver side + rough idling
  245. Idler arm problem? Right tie rod end?
  246. Intake tube not CA compliant
  247. EGR problems...
  248. '92 4WD 3.0 V6 not a clogged fuel filter but truck will decelerate and quickly rtn nm
  249. ***[OFFICIAL] PROJECT: STEEL BEANS Build Thread***
  250. How to remove and clean intake 87 22re
