Need help with fuel hanger
Old May 1, 2024 | 01:52 AM
Chevota808's Avatar
I needed a fuel tank since I bought a 2wd 85-88 toyota pickup frame that didn’t have the fuel tank. I ordered a fuel tank from AutoZone and I cannot find the correct hanger and sender assembly. It’s a 13.7 gallon tank if anyone has pictures of the two brackets In the 13.7 gal tank so I could order or point me in the right direction to get one that would be awesome! I have pictures of the tank and both holes seem smaller then the 17 and 19 gallon tank
Old May 1, 2024 | 06:27 AM
Jimkola's Avatar
YT Community Team
5 Year Member
That tank would have been in the very basic truck, RN50 (reg cab shortbed)
Your engine is EFI? The 17 gal tank wouldn't fit?
Old May 8, 2024 | 11:36 PM
Chevota808's Avatar
the 17 gallon is too long to fit so I’m trying to find the hanger and sending unit for the 13.7 gallon tank or where I can order ut
Old May 9, 2024 | 05:53 AM
Jimkola's Avatar
YT Community Team
5 Year Member
The reason i was asking is the 13.7 was in the basic truck, and that was carb. So no fuel pump in the tank. It was a mechanical pump bolted onto the head.
The fuel sending unit for a 1985-88 RN50 is 83320-39456.
The next gen truck, the RN8, had an EFI with a 13.7 gallon tank. It may work. that would be 1990 or so.
Old May 14, 2024 | 11:07 PM
PhoenixCarney's Avatar
Any update?
Edit: Seems no
Old Dec 13, 2024 | 09:45 AM
Chevota808's Avatar
Originally Posted by PhoenixCarney
Any update?
Edit: Seems no
figured it out got a 13.7 from AutoZone bolted in a 17 gal hanger and cut the tube to fit🤙🏾and routed the fuel lines
coopster
Dec 25, 2023 10:09 AM
nottoshabi
May 8, 2022 03:18 PM
bigwill837
May 22, 2021 10:59 PM
modlite
Oct 24, 2010 05:28 PM
