corroded taillight bulbs
Old Apr 30, 2024 | 10:30 AM
jdfnnl's Avatar
Quick question about the best way to loosen bulb / socket that has become fused by corrosion. After disconnecting and unmounting the taillight, I have thought of a baking soda / water solution, liquid wrench, soap, etc. Repeatedly applied with a brush then wiggling until loose after which a full treatment with steel wool, wire brush etc. What may be the best treatment for getting these loose?
Old May 1, 2024 | 11:54 AM
Jimkola's Avatar
YT Community Team
5 Year Member
PB blaster might work.
Baking soda mixed with vinegar might be worth trying too. Both are highly under rated and cheap.
Old May 1, 2024 | 07:12 PM
RAD4Runner's Avatar
Just soaking in plain vinegar is best because rust is alkaline (oxidized metal). Vinegar would dissolve it. I use exactly that for zipper pulls oxidized by saltwater, as well as badly-oxidized brass.
Alkaline baking soda combined with acidic vinegar turns into salt, not as aggressive against the alkaline rust, and also cause more rust.
Old May 8, 2024 | 04:54 PM
jazz1's Avatar
5 Year Member
Pickling/cleaning vinegar is higher acidic content. 7%. Rust will fall right off anything soaked in vinegar. Do not soak CAST in vinegar..it will get eaten! Use silicone grease on bulbs/ socket to prevent corrosion.
I’ve done 3 frame off restoration of vintage autos and a bucket of vinegar always on hand for soaking small parts.
spddm0n
Apr 25, 2017 09:50 AM
Tubbyfatty
Aug 26, 2009 03:30 PM
sixt5
10
Oct 10, 2008 05:10 PM
Andrey
Jun 27, 2007 10:30 AM
BOK
Jul 6, 2004 12:22 PM
