General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
bulb wattage
Old Oct 7, 2008 | 08:12 AM
sixt5's Avatar
bulb wattage
this weekend im gonna be installing my procomp light bar with two hella 500's and two 700ff's. all have 55w bulbs and that simply wont do. with some searching, summit has h3 bulbs in 100 and 130 watts for around 7 dollars.
put :
100s in all ?
130s in all?
100s in the 500's and 130s in the 700FF?
Also, will this be a problem with my alternator?
Thanks yota tech!
Old Oct 7, 2008 | 08:22 AM
OSU4Runner's Avatar
I have 100 watt bulbs in my Hella 500's and 500ff's, work great for me....never had a problem. I don't have any experience with the 130 watt bulbs though.
Old Oct 7, 2008 | 11:24 AM
Elton's Avatar
i got 100w bulbs in my 700ff's no problems yet just make sure to run at least 12ga wire
Old Oct 7, 2008 | 12:08 PM
OSU4Runner's Avatar
x2 I ran everything with 12ga wire as well
Old Oct 8, 2008 | 02:19 AM
sixt5's Avatar
i think i've decided to run 100s in all four lights. now when i go to wire them up, im using 12g wire but what amp fuse should i run? all four lights are going to be on one switch.
Old Oct 8, 2008 | 06:07 PM
Jay351's Avatar
40amp. I might upgrade the power/ground wires to 10 guage if you're runn that many lights off one wire..
Old Oct 9, 2008 | 02:16 AM
sixt5's Avatar
ok i think im going to run two relays, one for a set of 2 lights. simply cause this is going to be a lot of watts for one little switch. is there a diagram showing how to wire two relays together? also, will two 30 amp relays do the trick?
Old Oct 9, 2008 | 02:20 AM
Elton's Avatar
two 30amp relays will be fine to run both of them just run the trigger wire off the switch to the relays
Old Oct 9, 2008 | 10:12 AM
Jay351's Avatar
Yep. That will work just fine.
Old Oct 10, 2008 | 01:28 PM
sixt5's Avatar
can someone draw up somethin in paint for me? showing where the four terminals go to on each relay? thanks!
Old Oct 10, 2008 | 05:10 PM
Jay351's Avatar
here you go
RyanJ989
11
Apr 7, 2021 09:41 AM
CPD4runner
9
Nov 5, 2017 06:01 AM
clok
Nov 19, 2015 01:09 PM
4banginRunner
Nov 13, 2015 05:23 AM
Scotttekoch
Sep 28, 2015 10:30 PM
