Egr delete
Old May 11, 2024 | 09:38 AM
probert's Avatar
Egr delete
Hey need some help. Did the egr delete on my 4 runner it runs but then dies. Did vacuum leak test no leeks. How did yall keep it running in idle or how did yall get it to not starve from air any help or advice is appreciated
Old May 13, 2024 | 02:33 PM
Freewheel's Avatar
5 Year Member
I didn't have any trouble, I took mine out when I replaced my carb with a Weber. I got the LCE block off plates. They recommend using sealant on the plates. If you kept your OEM carb then you want to keep everything except the EGR valve itself, the LCE instructions say. There are 3 vacuum switches to remove if you replace the carb. You might look at the LCE instruction vid on youtube. Good luck and let us know if you find the problem
Jackalope77
Jan 23, 2024 03:47 PM
khat toy
Nov 30, 2014 10:25 PM
poppy
Apr 4, 2010 11:12 AM
kingbrian
Jan 13, 2009 05:08 PM
90_4runner
Nov 11, 2008 10:42 AM
