Possible diagnoses/differential for high pitch whine
Old May 23, 2024 | 07:05 AM
hokiedoc2022's Avatar
Not trying to be-labor the forum with another “what’s this noise thread” but I wanted to poll people’s thoughts so I’m not missing anything.
Symptom: High pitched ring/whine when in all 5 gears, when the engine is coasting/ not under load; most commonly rpm ~2500. Goes away when load is applied or when I depress the clutch. Truck is silent in all speeds when in neutral and coasting.
Differential diagnosis list:
- Synchros; just rebuilt my transmission myself with new synchros, bearings, etc; everything was within spec to FSM
- throw out bearing (seemed fine when I spun it by hand, that and clutch was replaced 20K miles ago) and would expect sound to get worse when clutch is applied
- pilot bearing (no issues shifting, sound not linear with RPM)
- serpentine belt pulleys? (Cannot replicate the sound with car still and revving engine with stethoscope)
- belt tensioner? (No rattling coming from engine or valve cover with stethoscope; no chain play when I redid valve lash 2 mo ago)
- pinion bearing? (Not present when coasting which is what I would expect if it was)
Y’all have any other thoughts on what it could be? Or feedback on my reasoning if it’s faulty.
1987 4Runner SR5, 22RE
Old May 24, 2024 | 07:37 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Was the noise there before the trans rebuild?
Old May 24, 2024 | 07:54 AM
Thanks for the reply. The sound was there before the rebuild.
I am pretty sure I found the cause and it’s a bad CC. I had been running rich for a while before fixing a faulty AFM. I’m pretty sure that expedited the CC breakdown. Hopefully this will be helpful for people in the future.
Old May 24, 2024 | 06:08 PM
Jimkola's Avatar
YT Community Team
5 Year Member
Magnaflow?
Old May 24, 2024 | 06:28 PM
It is a walker, I had it replaced a couple years back but never got around to fixing the rich condition until recently.
Old Jun 4, 2024 | 05:56 AM
StevenTucker's Avatar
Is everything good now?
Edit: Seems yes.
AMOUNTAINLYON
Oct 8, 2014 06:31 AM
cutter
Jul 14, 2009 07:20 PM
ato178028
10
Jun 13, 2009 05:34 AM
Beaniam
Jan 12, 2009 12:45 PM
Rayday81
Jul 1, 2004 05:23 PM
