I need some help
Old Jul 14, 2009 | 03:35 PM
cutter's Avatar
I need some help
My truck squeals and I want it to stop. Sounds kind of like a bad bearing...metal on metal sound. It only happens when it's under load though so I can't trace it while parked in the driveway. I can notice it most when climbing a mountain pass, it sounds like its coming from the passenger side but thats only judging by the echo off of the meridian. I have changed my belts, idlier pulley, the clutch is new so its not the needle or throw out bearing, and its not a brake squeal. does anybody have any ideas on where i should look next?
Old Jul 14, 2009 | 05:59 PM
desertcamper67's Avatar
Take a look at your belts. Look at the side that rides on the pulleys.
Old Jul 14, 2009 | 06:00 PM
Sorry. I just read your post completely. Okay new belts. Check the tension on the new belts.
Old Jul 14, 2009 | 06:12 PM
Lumpy's Avatar
Is this happening under load or at high RPM's...You can be under load at lower RPM or does this happen or only when screaming up a long hill? If it's at high RPM it maybe a bearing on the alt or belts not being tight enough?
Old Jul 14, 2009 | 07:20 PM
cutter's Avatar
Its the same squeal I had with the old belts, I have adjusted the belts a couple of times to make sure its not them. I'm worried it could be my A/C compressor
