Hood support adhesive
Old Apr 16, 2024 | 05:41 PM
h0runner's Avatar
Aye yotatech bros, quick question that hopefully someone can help me with. Does anyone know what kind of adhesive is used to bond the under hood support structure to the hood? Like the ribbing that is under the hood. Mine has gotten old and cracked up and now the support is floppy causing parts to crack and the hood to sag. I’ve welded the cracks and it helped but it’s happening again because the adhesive blobs aren’t stuck anymore. I really don’t want to get a fiberglass hood.
I tried some 3M weather strip adhesive and it only lasted about a month. Hopefully someone knows the oem stuff or something close.
thanks!
Old Apr 16, 2024 | 08:00 PM
Melrose 4r's Avatar
5 Year Member
There’s a two part 3M adhesive for this. I used it on mine. Not cheap.
Old Apr 16, 2024 | 08:01 PM
h0runner's Avatar
@Melrose 4r Happen to have a name of it for me? Even if it’s a little pricey that’s fine, I just want something that’ll last.
Old Apr 16, 2024 | 08:03 PM
Melrose 4r's Avatar
5 Year Member
Had to look it up…It’s 3m body panel adhesive 08115.
there is a special gun and nozzle that mixes it.
I bought it at a body shop supply store and they loaned me the gun.
Old Apr 16, 2024 | 08:09 PM
h0runner's Avatar
Found it for $150, not bad if it’ll last. Has it held up well to the heat under the hood? I don’t have any kind of insulation mat under my hood. Actually I don’t think any old yotas have that.
Old Apr 17, 2024 | 03:43 AM
Melrose 4r's Avatar
5 Year Member
Yes, it holds up. I think it is as good as OEM and used for other bodywork purposes mostly. Good luck!
Old Apr 17, 2024 | 07:40 AM
mechkw's Avatar
I would think something as simple as a clear silicone adhesive would work from the local auto parts store for about 5 dollars. As long as the surface is clean that you're adhering to, there should be no problem with it staying there and will certainly last in the heat of the engine bay
Old Apr 17, 2024 | 08:00 AM
Jimkola's Avatar
YT Community Team
5 Year Member
I tried regular silicone caulk and it only held for about a year.
I used Liquid Nails adhesive after that and it's held. About 3 years so far.
I did ponder self leveling adhesive caulk, the stuff used to seal vents on rv roofs. that stuff seems to stick to anything, i just wasn't sure if it would "flatten out" and not fill the gap between the ribs and the actual hood panel.
Old Apr 17, 2024 | 09:09 AM
h0runner's Avatar
Liquid nails might be a good option too. I wonder what kind of heat it can handle though. My hood gets warm enough to steam in the cold when it’s raining and I’m sitting still, even though I don’t have an overheating problem.
Old Apr 17, 2024 | 09:36 AM
mechkw's Avatar
Originally Posted by Jimkola
I tried regular silicone caulk and it only held for about a year. .
Silicone caulking and silicone adhesive are 2 different things
Roofmaster
Oct 17, 2012 06:32 PM
FUZION
Jun 14, 2005 01:21 PM
shore_caster
17
Dec 2, 2004 06:17 AM
NerfHerder-97SR5-
Aug 18, 2002 12:56 PM
