Heater not working help
Old Feb 15, 2024 | 06:34 AM
clok's Avatar
So my heater just suddenly stopped working in my 1989 4Runner v6 , can anyone please point me in the right direction on things to check to see what happened , thanks in advance
Old Feb 15, 2024 | 07:03 AM
akwheeler's Avatar
check fuses and grounds. Apply power and ground directly to the fan motor and see if it is still good.
check the switch and the blower motor resistor.
Old Feb 15, 2024 | 07:08 AM
clok's Avatar
fan turns on the a/c works perfectly just the heater doesn’t throw out hot air when I move the lever to heat 🤷🏽‍♂️
Old Feb 15, 2024 | 07:14 AM
akwheeler's Avatar
This is why it is important to ask the right questions.
check that your coolant level is full, move the heater control and look at the hot/cold valve that should be on the firewall near the center and see if it is being moved by the cable when you move the lever.
backflush the heater core
Old Feb 15, 2024 | 07:31 AM
clok's Avatar
ok will check it out thank you
weaselman
Feb 22, 2014 07:32 PM
KNou
Nov 18, 2010 04:26 PM
yodercrawler55
Jan 14, 2009 04:47 AM
Trustyrusty
Nov 1, 2008 11:05 AM
