Steering box adjustment?
Old Apr 13, 2024 | 11:12 AM
cashmoney00's Avatar
Before I go buy a new steering box, are there any adjustments that can be made to tighten them up?
Old Apr 13, 2024 | 11:58 AM
Discombobulated's Avatar
You can adjust to a point, adjustment is on top of the unit. This thread explains some stuff,
https://www.yotatech.com/forums/f116...ebuild-221006/
You can go too tight and it drives funny, so when I did mine it was little at a time, but I still needed to replace as tightening didn’t take care of my slop….
Old Apr 13, 2024 | 04:54 PM
scope103's Avatar
This part of the FSM https://web.archive.org/web/20120915...12gearhous.pdf (page 10) describes the adjustment procedure. It is intended to be bench-tested with a torque wrench that can read down to 1.7 in-lbs, but it will give you the idea of how to adjust it on the truck.
Old Apr 13, 2024 | 06:50 PM
Melrose 4r's Avatar
5 Year Member
I find it best to raise the front wheels off the ground when making the adjustment. That way you can tell if you’ve overdone it. You’ll feel the box bind without the drag of the tires on the ground.
Old Apr 13, 2024 | 07:45 PM
ryanthegreat1's Avatar
Probably worn out in the center. Adding and more preload to fix the center is going to quickly blow out the less worn areas. See it frequently on saginaw boxes.
Old Apr 14, 2024 | 07:35 AM
Jimkola's Avatar
YT Community Team
5 Year Member
Well, if replacement is on the table, takes yours out and take a look.
If the gears look ok a seal kit is pretty cheap.
It's also easy to adjust when it's out.
Old Apr 14, 2024 | 11:14 AM
Oh I’m sure it’s worn out. You can turn the wheel almost a quarter turn before it moves. Some of it is the pitman arm which is on the work bench to be replaced. Just trying to prolong the usage before I drop the money.
Old Apr 15, 2024 | 12:34 PM
Jimkola's Avatar
YT Community Team
5 Year Member
It doesn’t take much play at the box or pitman arm to translate to sloppy steering at the wheel. Your call, but it takes all of 5 minutes to open up once it’s out. Worst part is the pitman arm, and it sounds like that’s already off.
Old Apr 15, 2024 | 12:39 PM
I just did the pitman arm and pretty certain it's a record. Tools out to tools up in 20mins. Gonna go drive it here in a bit and see what difference it made.
Old May 11, 2026 | 10:00 AM
JoeS's Avatar
Leaking Steering Box
On my 86 2WD truck the front seal on the PSG was leaking badly at 430,000 miles. Had no intention of rebuilding it, so I went aftermarket. Tried 3 units from 3 different brands and they all bolted to the frame perferctky.
The problem with all three was the PSG input shaft was slightly too large in diameter for the rag joint to slip into. Spline count was the same. The last one the store manager personally delivered it. I showed him how that one too did not fit, then showed him how the leaky original slid on easliy. He shook his head and drove away. These rebuilt units where about $125 back then
I tried an online slavage yard parts search and had a place in WA State ship me an original Toyota unit (had Toyota name in the casting) that bolted up and the rag joint slipped right on. Still doing good at now 494,000 miles. It was also $95 w/shipping from WA.
Lesson learned.
TORTIS
Jan 11, 2012 04:14 PM
Blizzard
Dec 3, 2008 01:53 PM
hilux
Jul 24, 2003 06:43 AM
