2nd gen linear clutch spring mod
Old Mar 27, 2024 | 08:14 AM
Dawsonmarch's Avatar
Hey all,
I recently manual swapped my 94 Hilux surf (RHD 4runner equivalent). The torsion springs are a bitch so I've swapped to a linear spring. I've read a bunch of forums on it, but I think they are mostly for 3rd gens which seem to be a simpler straight swap. I've found that on my 2nd gen that the clutch pedal bracket gets in the way and rubs on the spring. I've had the most luck with a very bent up 2nd gen 4runner brake pedal spring, and there is very little rub with it. I also ordered the proper clutch pedal spring that most people recommended but it rubbed really bad, and I couldn't bend it up to fix it much, so sticking with my brake pedal spring. Has anyone found an elegant solution with no rubbing for the 2nd gens?
Thanks
Clutch spring
Brake pedal spring (currently using with minor rubbing)
partynoparty
Sep 19, 2022 08:27 AM
86_runner
23
Jan 10, 2018 05:22 PM
IDM
9
Oct 15, 2014 11:11 AM
turbo8
Nov 7, 2012 05:02 AM
habanero
Nov 10, 2009 12:53 AM
