4runner clutch return spring, stiff clutch
Old Nov 5, 2012 | 10:14 AM
turbo8's Avatar
Is a return spring required for the clutch pedal to return?
I took out the torsion spring and replaced it with a extension spring from a local hardware store.
Clutch pedal was stiff with torsion spring and extension spring.
I removed the extension spring and clutch pedal is a little softer and clutch pedal returns normally.
Is this normal?
clutch and pressure plate were replaced a year ago along with slave cylinder and a rebuilt master cylinder.
Old Nov 6, 2012 | 08:14 AM
mschein1's Avatar
your clutch master cylinder will return the pedal for you.
Old Nov 6, 2012 | 08:31 AM
turbo8's Avatar
Thanks, so why do people put the extension spring on after the removal of the torsion spring?
Old Nov 7, 2012 | 05:02 AM
mschein1's Avatar
Preference. I am running a linear spring after taking out the torsion spring. It is a little firmer with the spring than without. I prefer that.
smthwsn357
May 1, 2024 07:28 AM
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
Nickdigg
Jul 7, 2015 06:04 AM
