Rich running. How to lean out?
Old Feb 7, 2024 | 05:00 PM
DiabloYota's Avatar
1991 2wd 3.0, with 3k miles on rebuilt motor. All stock.
My 3.0 is running really rich. While I don't need a smog check now, I had it checked and it's in the "gross polluter" realm. Exhaust smells like fuel.
All vacuum tubes checked. EGR working properly. Air injection working. O2 sensor working, although putting out the full 1 volt. No fault codes. Timing is correct. It idles fine.
What is the sequence of things to do to get this rich condition fixed? I'm reluctant to just start throwing parts at it (injectors, MAF, plugs, etc.). Is there anything short of hacking the ECU to lean it out a bit?
Old Feb 7, 2024 | 09:00 PM
millball's Avatar
Perhaps the ecu is not not going into closed loop.
Have you tested the engines coolant temperature sensor.???
Old Feb 8, 2024 | 07:19 AM
DiabloYota's Avatar
I can check the temp sensor. How would I know if it's not running in closed loop?
Old Feb 8, 2024 | 07:54 AM
millball's Avatar
"How would I know if it's not running in closed loop"??
That's a good question and I don't know off hand what the FSM says about that.
I would expect that a fluctuating O2 sensor reading would give an indication of closed loop, but IDK for sure.
I do know that if the coolant temp sensor does not give the ecu the good word, closed loop will not occur.
I'm sure there are other parameters that must be satisfied as well, but that is the first place to look.
I have an old Snap-On MT2500 scanner with Toyota OBD-1 proprietary software that can tell me about open/closed loop, but that doesn't help you any.
Old Feb 9, 2024 | 03:19 PM
DiabloYota's Avatar
I was checking the leads on the MAF, per the FSM. All combinations had the correct resistance. But...I noticed that the connector is missing a female lead. Can someone check theirs and tell me if this is wrong?
It's the connector to "E2" on the MAF.
Old Feb 10, 2024 | 03:16 PM
millball's Avatar
That plug looks the same, with that one lead empty, on my 1992 4runner wreck.
Old Feb 10, 2024 | 04:09 PM
DiabloYota's Avatar
Great. Thanks for the info.
mylittlepony1
Jan 13, 2014 12:10 PM
TinMan
Dec 6, 2011 08:12 PM
yota4life6
Apr 14, 2009 10:28 AM
coolboatguy
10
Aug 21, 2006 01:02 PM
seafarinman
11
Sep 15, 2004 01:48 PM
