Made a dumb mistake and need advice
Old Jan 15, 2024 | 02:33 PM
CarsonBrown406's Avatar
So today I replaced the battery in my '87 4runner. It was -15° so I was rushing, and I put the battery in the wrong way around and hooked the positive to the negative post and the negative to the positive post. It was such a rookie mistake and I can't believe I did it, but here I am. So I switch the battery around and hook it up correctly, and now there are no lights on the dash, it won't crank, there is no power to anything. I checked all the fuses in the engine bay, and under the dash on the driver's side. There was only one blown fuse, a 7.5 under the dash. I'm not even sure what that particular fuse does, but I replaced it and nothing changed, still no lights on the dash and no crank. Somebody please tell me I haven't fried the ECU or anything. What should I do next?
Old Jan 15, 2024 | 03:38 PM
cashmoney00's Avatar
Is there a fusible link in these trucks that possibly blew?
Old Jan 15, 2024 | 06:04 PM
Discombobulated's Avatar
Edit: my link went weird, if you search battery backwards you weren’t the first to make this mistake lots of threads on the topic.
Old Jan 15, 2024 | 06:26 PM
sam12843's Avatar
There is a fusable link near the fuse box, inspect and confirm with a multimeter it isn't blown, these tend to go sometimes before it even hits the fusebox. Link below outlines how to replace it and should give you a good idea which wire it is.
https://www.yotatech.com/forums/f116...cement-228307/
gdavis67
Jun 3, 2014 12:09 AM
EagleX
Jun 24, 2009 03:54 PM
