Push-started...now dash lights won't work!
Old Jun 24, 2009 | 07:11 AM
EagleX's Avatar
I have a 1993 Toyota Pickup 22RE 2wd 5-speed. My bro accidently left the lights on when we were working on a taillight testing it out, and drained the battery. Anyways, got it rolling on a hill, and it push started fine, however, the dash lights suddenly do not work at all. Headlights and everything else is good, but all the instrument panel lighting is dark, around the gauges, heater knobs, everything. The interior dome light is fine too.
I check the fuses in the box in the engine, but they seem fine. Did I blow another fuse somewhere? This is probably an easy fix...duh...I just don't know it!
~ Justin
Old Jun 24, 2009 | 07:28 AM
algranger's Avatar
You probably shorted something out while doing the tail light and blew a fuse
Check the fuse box in the cab, it's on the left side about a foot off the floorboard kind of under the dash.
Oh and just for future reference.. it never hurts to disconnect the neg battery cable before messing with the electrical that way you CANT short anything out
Old Jun 24, 2009 | 11:20 AM
sdstud212001's Avatar
are you sure the dimmer switch is not turned all the way down?
Old Jun 24, 2009 | 12:05 PM
Ezrider_92356's Avatar
check and see if your tail lights are working if they are not its the fuse in the drivers side kick panel
Old Jun 24, 2009 | 03:30 PM
Flash319's Avatar
Old Jun 24, 2009 | 03:38 PM
slisdexia's Avatar
sometimes it's hard to tell if a fuse is blown. try a new one. that way you'll feel dumb if everything comes back.
Old Jun 24, 2009 | 03:54 PM
KVRunner's Avatar
The dimmer switch was my first thought too. It would be the first thing to check.
Cesarl74
Apr 23, 2016 06:07 PM
irish_tyrant
Jul 6, 2015 11:22 AM
Valvoman
Jun 28, 2015 02:45 PM
Taz22R
Jun 21, 2015 04:44 PM
ShaunKris
Jun 17, 2015 04:33 PM
