truck wont stat... No power to dash or cluch cancle button... nothing doen please hel
ok i am new here and learning alot about toyotas. Thanks to all you guys who post great info i just managed to do my timing chain.. The worst part the oil pan grrr.. till now Here is my problem got every thing back together and the truck wont start... not even a click of the sel. no dash lights no radio. no cluch start cancle button. battery is good turned lights on good and bright. i did not disconect the battery and i did accidently tuch "something" and sparkes flashed ect... I figured i just blew a fuse and was planning on dealing with it when i was done.. But there are no visably blown fuses checked them all. Any thoughts or suggestions as to what is going on? Please help
thanks i did check all grounds again and then again... turned out to be my 80 amp fuse... and posible ground but the fuse was def shot.. pulled one out of the 4runner and she started right up... thanks
bsinwa
19
07-13-2006 09:39 PM
Briareus
10
08-24-2002 05:33 PM
