Can anyone identify this noise
Old May 19, 2024 | 04:09 PM
Zeddi's Avatar
I changed my timing belt and water pump and this is the noise it made when trying to crank the engine over for the first time
I thought I did everything correct but apparently not any advice helps thank you
File Type: mov
Old May 21, 2024 | 09:45 PM
osv's Avatar
osv
weird, it's like the starter is encountering too much resistance?
can you turn it over by hand, with a socket on the crank pulley bolt?
Old May 22, 2024 | 05:35 AM
snippits's Avatar
Sounds like the starter pinion gear is engaging then retracting very fast in rapid succession. Hopefully, you did not lock the motor up. Try to turn it over by hand as suggested above by @osv .
Slayer99
Aug 26, 2021 06:30 AM
rbh261
14
Jun 11, 2011 08:35 AM
lovemyrunner
Apr 20, 2009 05:19 PM
the"RoadRunner"
Feb 16, 2007 10:26 PM
KING
12
Feb 3, 2006 01:09 PM
