Crank No Start
Old Feb 29, 2024 | 04:42 AM
91 Toyota Odyssey's Avatar
Crank No Start
Help!
I recently replaced the battery and alternator on my 91 Toyota pickup (converted into a class c RV by leisure Odyssey). In the process of replacing the alternator, I needed to remove the distributor to get the alternator out/back in. When I put everything back together, it cranks but won't start.
​​​Any advice would be greatly appreciated!
Old Feb 29, 2024 | 06:39 AM
scope103's Avatar
Does the distributor rotor turn when the engine turns over? When the crank is set at TDC, is the rotor pointing a few degrees before the #1 plug post? (or 180° away, as there are two TDCs per revolution of the distributor). Did you follow the directions on re-installing the distributor (the drive gear is a helix, so the match-marks take the twist into account).
Old Feb 29, 2024 | 09:26 AM
I haven't checked the distributor rotor while turning the engine over yet. After setting the crank to TDC the last time, I removed the distributor cap and noticed the rotor might have been just at or after #1 plug. I thought I re-installed the distributor correctly but, its possible I missed something.
Old Feb 29, 2024 | 11:30 PM
snippits's Avatar
About as good as it gets on how to install the distributor.
Old Mar 4, 2024 | 09:20 PM
IslaBaxter's Avatar
Thank you so much for the video. I want to install a 22E distributor but I don't know how can I install it.
Edit: I installed it.
Thrawn
Jul 23, 2016 01:22 AM
wizard0ne0
Nov 20, 2010 05:09 PM
Beaniam
Mar 7, 2010 01:42 PM
nfleuks14
Sep 11, 2008 10:52 PM
Yamaha+Toyota=Fun
Nov 7, 2005 07:27 PM
